Ignition switch
/ Ignition switch #1
swimpy
Looking for a replacement ignition switch for my Iseki
Landhope 220.
If it helps any, the switch is located on the right side of the
steering column.
Thanks,
Terry
/ Ignition switch #2
Terry,
I replaced the switch on my TU150FD about 6 months ago. I ordered it online thru Yenibiz.com - they're in Belgium. The switch for my tractor has 6 posts - the replacement has wiring instructions for 3 of the 6. It took me a couple of hours to ascertain the postion for the other 3. I got lucky the first try.
The reason I mention this is because the replacement is not identical but it's close. The markings on the back of the original switch do not correspond with the back of the replacement. I did keep the diagram.
Slight modifications were needed for securing the wires to the posts of the new switch.
There are probably other places to get a swich but I was ordering other items as well. I was impressed with the web site and the amount of Iseki replacement parts. I did check with a tractor company here but the price overseas with shipping was cheaper still.
Yell if I can help.
/ Ignition switch #3
I can probably supply the OEM switch.
/ Ignition switch
I Guess I should probably begin at the beginning.
The tractor will start and run, but will not shut off.
Ignition switch?
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
1995 John Deere 7400 (A60462)
1995 John Deere...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
