Ignition switch problems
   / Ignition switch problems #1
cliffoflancing
LEBANON TN
MITSUBISHI D1600 FD
Mitsubishi D1600 FD Grey Market Tractor, Ignition switch, replaced a couple and they last about 1 year then become inoperative. Does anyone have an answer to this problem ?
   / Ignition switch problems #2
Many switches are exposed to water and sun.
That being said the lubricants inside get kinda fried, stiff and prevent good contacts.
Having dissected a few I noted the causes.
My cure has been to squirt some WD40 into the key slot which in most cases cured the problem.
Try it it casts peanuts!
Good luck.
I suggest WD40 as it is non corrosive.
Good luck.
Thank you PILOON for your prompt reply.
16ft T/A Flatbed Trailer (A52377)
16ft T/A Flatbed...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2013 CAT 246C (A47477)
