ignition switch problem with TC 33D, 2003
/ ignition switch problem with TC 33D, 2003 #1
jsinus
ca
newcanes holland tc33d
the ignition switch will not turn to start when
key inserted. how do I remove the panel to get at the switch? :) thanks I
n advance for any advice:eek:
/ ignition switch problem with TC 33D, 2003 #2
Welcome to TBN. :)
/ ignition switch problem with TC 33D, 2003 #4
This is an easy fix. There are two bolts on the center section below the steering wheel and two more bolts, if I remember correctly, on the fire wall. Take them out and the panel lifts off. I would watch out for the brake peddle when you take it off as you may scratch the panel on the side of the peddle.
Tennant M30 (A64127)
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
OVERHEAD PROJECTOR, HP PRINTER, (2) MONITORS (A64276)
OVERHEAD...
2019 Ram 3500 4x4 Reading Service Truck (A61573)
2019 Ram 3500 4x4...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
2017 Toyota Tundra 4x4 Crew Cab Pickup Truck (A61573)
2017 Toyota Tundra...
