Ignition Switch or??
/ Ignition Switch or?? #1
finspop
Hello,
I'm wrestling with a few gremlins on my 3910; right now, I'm dealing with what I hope is just an ignition switch issue (as opposed to a potentially more complicated and harder to diagnose electrical issue). Here's what's happening:
When the tractor is off, the dash lights are powered up (horn works too, haven't check headlights but I assume they'd work too) no matter what the position the key is in. Once I start the tractor, all the lights go off. But when I shut it back down, everything stays on and slowly drains the battery.
For the time being, I am simply disconnected the neg cable on the battery, but I definitely want to fix this issue.
I'm planning to start by replacing the ignition switch, since it's cheap and simple. But I'd like to get ideas on what else I might troubleshoot, or if it's obvious to anyone that this is NOT a problem with the switch.
Thanks.
/ Ignition Switch or?? #2
From the symptoms I would be more inclined to look at the voltage regulator and related wiring. Try unplugging the regulator and see if the key controls the gauges, light etc better.
/ Ignition Switch or?? #3
I would also check the chassis ground and make sure that the neg bat. cable is making good contact with the frame.
/ Ignition Switch or?? #4
Have you owned the 3910 since new? Is this a new problem that just developed? It sounds like you may have a short somewhere that is connecting your light circuit to the hot battery bus. If someone previously owned the machine, they might have done a wire modification. You also could have 'mouse modifications' to the circuits.
Your ignition switch can be checked pretty easily by removing it and running continuity checks when it is turned off. Does your engine stop when you turn the key to off? If it does, then your ignition switch is probably okay.
Thanks, everyone. The tractor is fairly new to me; I've put about 50 hrs on it in the few months I've owned it. This issue just cropped up.
Jinman, this tractor has a fuel shutoff cable to stop the engine. In other words, no, it doesn't stop with the key, but it's not designed to.
I'll try the other suggestions and report back. While I'm halfway decent at basic wrenching duties, I'm also one of those poor saps who really struggles with electrical stuff. Maybe this will be a good opportunity to improve my skills!
Anyway, thanks again!
So in the process of removing the ignition switch to run some tests, I fiddled with the wires a bit and got it working. Seems like there's a suspect contact at one of the terminals or perhaps even inside the switch. Anyway, it's working for now, and I've got a pretty good idea where to start if the problem crops up again.
Now onto my other little fixes: Broken tach adapter and broken fuel shut off cable. All three - the switch, the tach, and the fuel shut off - crapped out in the same week!
Thanks, everyone.
/ Ignition Switch or?? #7
if i found it was bad.. I'da replaced it before putitng back in... just sayin....
I would've, but I have the cluster out anyway, to replace the fuel shut-off cable. So while I wait for the cable to arrive, I'll have a few days to see if it's working with things still torn apart.
/ Ignition Switch or?? #9
wow.. had to pull the cluster for the stop cable? they must have moved them. didn't have to do that on a 3000 i worked on.
Yeah, to get the nut off the backside of the dash... pretty easy, actually... four screws and it just pops out.
/ Ignition Switch or?? #11
i was able to go up under the dash to get the retaining nut off my kill cable. and I'm quite familiar with the 4 screw ford dash. to have to go thru the dash..they must have moved the pull cable way, way up.
not sure if they moved it... I don't have as much experience as you with these tractors. The kill cable is just above the ignition switch on this one. Also, I have a cab, which probably complicates things.
/ Ignition Switch or?? #13
the cab very well could be a huge complicating matter. if you can't get the under dash cowling off and reach up, while standing next to the tractor.. it would be difficult.
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2013 HERCULES ALUMINUM KILL TRAILER (A60736)
2013 HERCULES...
