Ignition fuse issue
/ Ignition fuse issue #1
keljan11
Okanagan, BC, Canada
MF 265, Kubota B6200
Hey all,
I've finally figured out a cure for my ignition fuse issue on my MF 265.
History: -started blowing the 20 amp ignition fuse. Found it right after finishing cutting/raking/and baling my small hay field.
- dismantled my tractor dash as much as I could (because of cab on tractor). Removed the fel, hood, battery cover side plates, etc.
- changed out the amp meter, corroded braided negative cable, fixed a couple of poor electrical connections I found (lights, etc.). Still blew the ignition fuse.
-ordered a new alternator and installed it.
- since I had everything apart, decided to change the fan belt and the engine stop cable. I had also bought a new ignition switch just in case, but didn't need it.
Anyways, the new alternator was the answer. Fuse is holding!!
Hope this will help someone else
/ Ignition fuse issue #2
Not that I was aware of your search for an answer, but "Thanks!" Too many times I read lengthy threads, hoping for a good fix to a problem, only to discover the OP never posted which suggestion helped!
Think I had a few suggestions from others about checking the fuse holder connections, looking for a bare wire grounding out someplace (which is what I thought), etc.
Think what caused the whole issue to start with was the corroded braided ground cable. I think it caused the alternator's diodes or the voltage regulator to crap out. Therefore if you've got a braided ground cable and it's a little corroded, change it out.
Just hope my answer will help others
1991 John Deere 4455 (A64126)
1991 John Deere...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
Deutz-Fahr 6140 (A64126)
Deutz-Fahr 6140...
