Ignition fuse issue
/ Ignition fuse issue #1
keljan11
Okanagan, BC, Canada
MF 265, Kubota B6200
Hey all,
I've finally figured out a cure for my ignition fuse issue on my MF 265.
History: -started blowing the 20 amp ignition fuse. Found it right after finishing cutting/raking/and baling my small hay field.
- dismantled my tractor dash as much as I could (because of cab on tractor). Removed the fel, hood, battery cover side plates, etc.
- changed out the amp meter, corroded braided negative cable, fixed a couple of poor electrical connections I found (lights, etc.). Still blew the ignition fuse.
-ordered a new alternator and installed it.
- since I had everything apart, decided to change the fan belt and the engine stop cable. I had also bought a new ignition switch just in case, but didn't need it.
Anyways, the new alternator was the answer. Fuse is holding!!
Hope this will help someone else
/ Ignition fuse issue #2
Not that I was aware of your search for an answer, but "Thanks!" Too many times I read lengthy threads, hoping for a good fix to a problem, only to discover the OP never posted which suggestion helped!
Think I had a few suggestions from others about checking the fuse holder connections, looking for a bare wire grounding out someplace (which is what I thought), etc.
Think what caused the whole issue to start with was the corroded braided ground cable. I think it caused the alternator's diodes or the voltage regulator to crap out. Therefore if you've got a braided ground cable and it's a little corroded, change it out.
Just hope my answer will help others
Deere 772CH (A64126)
Wolverine Quick Attach Dozer Blade (A66285)
Wolverine Quick...
Wheel Loader Forks (A64126)
Wheel Loader Forks...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2002 Jeep Wrangler (A64127)
2002 Jeep Wrangler...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
