Ignition burns out glow plugs
/ Ignition burns out glow plugs #1
alifor65
West Monroe, LA
Mitsubishi Satoh S750
I just had a new ignition installed on my 1980 Satoh S750 and when you turn it to the left it doesn't heat the plugs. Instead it keeps burning out the glow plugs. Its not the original part but I was told its the universal part that all these models are using. Could it be a wiring/ground problem?
/ Ignition burns out glow plugs #2
The only way glow plugs can be burned out is by leaving power to them too long. If they are a 12 volt plug, that's the only thing that can cause them to fail. It's impossible to overpower the plugs with a 12 volt battery.
/ Ignition burns out glow plugs #3
Agreed. The switch is either incorrect for the application, wired incorrectly, or both.
/ Ignition burns out glow plugs #4
X3 it sounds like the glow plugs are actually wired into the 'run' position of the key and not into the 'glow' position
Jon
/ Ignition burns out glow plugs #5
I am not sure about your Satoh. However if it is the same as an older Kubota, the glow plugs are not designed to use full battery voltage. They have a resistor wired in series to drop the battery voltage down to the voltage they are design to use. If some one has removed the resistor or it has shorted and the glow plugs receive the full voltage from the battery they will burn out. Use a meter to measure how many volts is getting to the glow plugs when you turn the key to the glow position. Then find out what voltage they are designed to operate with. Some glow plugs have this identified on them or you may need to call a parts place.
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
2015 Ford Escape 4WD SUV (A61574)
2015 Ford Escape...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
