I am not sure about your Satoh. However if it is the same as an older Kubota, the glow plugs are not designed to use full battery voltage. They have a resistor wired in series to drop the battery voltage down to the voltage they are design to use. If some one has removed the resistor or it has shorted and the glow plugs receive the full voltage from the battery they will burn out. Use a meter to measure how many volts is getting to the glow plugs when you turn the key to the glow position. Then find out what voltage they are designed to operate with. Some glow plugs have this identified on them or you may need to call a parts place.
