If your Wallenstein chipper has a serial number, it is real.
   / If your Wallenstein chipper has a serial number, it is real. #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
The one I bought used from a farm contractor in the Ottawa area was advertised on Kijiji as a Wallenstein 4" pto chipper, and he had it set up for the same Kubota model as mine, a B7510. He said it worked well so I made the deal. The chipper did fit my tractor well and I had a great time chipping brush until the plate beneath the rotating spout became a problem. It shattered. Turns out it was made of black plexiglass.
I downloaded the Wallenstein BX42S Chipper Parts Manual, located the replacement parts, and ordered them from my local dealer. They arrived and I bolted the black metal pieces on. No problem.
I had paid more than the new price for a well-worn counterfeit, but it worked well. A niggling problem was that despite all of the decals on the chipper, it had no serial number.
I decided that I'd better check the torque of the nuts. The bearing nuts were all of different torques. One of the studs holding a cutter was loose, and another was sufficiently stripped to be questionable. A couple of others were way too tight.
It was time to turn the knives over, so last week I ordered replacement nuts from the catalogue. They came in promptly, but they were too large. The manual describes Z71372G8 as Hex Bolt 3/8NF X 5/8 G8, but Wallenstein sent bolts which fit a 14 mm socket and measure 10mm at the points where I measured 13 mm and 8mm on the one I took out. When my dealer called the manufacturer, their parts guy insisted that they had sent the right bolts.
So I need to find some bolts which fit. On the other hand, the counterfeit has done a pile of work over the last two years. I maintain a large yard and 14 acres of black walnut trees, and do a lot of chipping.
But still...
   / If your Wallenstein chipper has a serial number, it is real. #2
It was actually funny. Years ago, I was at some Mennonite shop that made a lot of parts for Wallenstein. There was some broken log splitter wedge they were messing with that was supposedly some knock-off and how annoyed they were. Wallenstein copied all kinds of stuff, made a name for themselvse and were then annoyed that someone would copy them. The audacity! lol
HUSQVARNA RIDING...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
Volvo EC220EL (A60462)
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
