If You Were To Get A New 6 Ft Finish Mower - What Would You get?
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #61
I know, more than you wanna read...
I had a Landpride FDR2572 six foot finish mower several years ago. It was very heavily built and probably as good as they come. That said, I am no fan of finish mowers no matter how solid/reliable. If you have a compatible tractor, get a belly mower instead. They do a nicer job in my opinion (Kubota experience) , are far more maneuverable & useful in tight spaces, and seem to take less HP that a finish mower takes (which puzzles me...) I ran the FDR 2572 on a JD 4700 for several years and it was more of a load on the tractor than a JDMX6 rotary cutter over the same terrain and grass/weeds. My Kubota MMM simply does a better job. I'm not talking a big open flat golf course type lawn -- I'm talking on areas cut once a month, often with grass let go too long, frequent small limbs, twigs, etc. It does depend an awful lot on what you will be mowing and individual facts of your terrain, surface, obstacles, etc.
Couple of pieces of advice:
Get the solid tires rather than pneumatic. The air filled tires I had on the Landpride were a constant PITA. I did make mistakes using the Landpride as if it were a bush hog but even so I detest those little air filled tires.
Another is be careful and keep the grease off the belts. Accidental grease on the belts equals burning up belts & they are expensive.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #62
I have a 6’ land pride I pull behind a 37 hp grand L and I could not be happier
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #63
I 'm wondering why if someone owns a tractor their yard is so rough.
Our yard was very rough when we first moved here.
I've spent a lot of time smoothing up our 8 acre lawn with the tractor.
Still has a few slightly rough spots, but night and day smooth compared to what it was.
apparently you don't have feral hogs in your area, lucky person. lots of talk here about what a beating one takes on rough ground....hog damage is by far chief culprit for me. fortunately the rough ride on the zero turn doesn't bother me, but feel for those who must endure those conditions.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #64
Get a Woods TK or TKP finish mower. They have the best cut quality and discharge pattern of any rear discharge 3-point mower in the industry. There is a study done by Penn State proving it.
I second this idea. I’ve owned an older Frontier GM2072R that was built well (originally built by Befco, just painted JD green and given “Frontier” stickers). It ran great but I sold it when I sold my tractor. I then purchased a Woods RD72 and now own a TKP84.20. The construction of the Woods model is top notch. As of yet, no complaints at all.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #65
Ok, I'll clarify a little.
Considering replacing my 6 foot finish mower.
The main thing I would like is not only a rear discharge but one with a good discharge pattern. Not one that discharges in clumps like mine does.
Mine has a "chute" type discharge at the rear so it restricts the discharge some and causes clumping. I first took the chains off and it was a little better then took the chute off and it is much better but it also blasts the left rear wheel with clippings turning it into a big green grass ball!
I've seen a few that look like they discharge across the whole back of the mower. Wondering how well these work?
It also needs to be a pretty heavy duty mower. Not so much blade wise but just overall construction.
The areas it will be used on are not perfectly smooth!
Thanks for suggestions. Used in great shape is also an option.
About 20 years ago I purchased a rear discharge LandPride Grooming Mower FDR2572. Excellent mower. The tractor that I used it on and most of the other smaller implements are all gone now but I've continued to hang on the mower. I mow with a zero turn mower now but the LandPride is there if I need it. I like to fabricate things so I've thought about modifying the zero turn deck to a rear discharge and modeling it after the LandPride design...maybe when I retire.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #66
Had a couple finish mowers. Woods rd7200 since 1999. Takes about 6 gallons of diesel to mow our many patches of grass and weeds. Been a good mower except for the caster wheels. Lot of back and forth for trimming. Solved that problem trailer spindles.
Found a few washers spacers under the rear casters to give a slight tilt to the deck really lowers the hp required and improves the cut quality. Gator G5 blades are also an improvement over OEM.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #67
I am DONE with Woods mowers.
I bought a PRD7200 brand new,,
EVERY decal fell off within 3 months,, Woods no longer offers all of the decals, only the safety ones.
Then, when the mower was about 6 months old, it started "SCREAMING"!
The selling dealer went out of business, I took it to the next closest dealer.
The service rep turned the pto shaft by hand, and said "some noise is to be expected",,
Well, two weeks ago my wife said;
"Get rid of the mower, the neighbors are complaining about the noise!!"
I checked the spindles with a mechanics stethoscope,, the excess noise came from the right spindle.
After an unbelievable amount of beating, I got the shaft out,,
Woods did not seat the race for the upper bearing properly, one side was "up" 1/8".
I sent Woods a couple emails since finding this,, they have not responded,, at all.
I have used the mower so little, I have never sharpened the blades once yet.
The owners manual says the spindles CAN NOT be rebuilt, simply replace the entire assembly,,
Yea, right,,
I installed two new TIMKIN made in France bearings,, after removing the made in China bearings.
The mower is quiet,, now,,,
Do not expect much as far as service,, if you buy a Woods,,
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #68
Words of wisdom get rear discharge if going into taller grass. The taller the height of deck less horsepower required. Get high lift blades to allow good chopping of the grass with tall deck. Any brand with all these features will provide good mowed yard. If this is rear mounted 3pt deck make sure it’s floating on 3 pt mount to eliminate any issues
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #69
the only mower that I REALLY WANT at this point is a Ventrac 4520 (not sure of the specific model yet)
Good choice. I love my 4520z. I’ve got a 72” finish mower for it that i’ve yet to try out. The tough cut deck is an amazing tool.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #70
New recommendation: Taylor-way 3-pt finish mower. I have an older Taylor-way 60" finish mower, and it does a great job. Their customer support was great when I had to replace a wheel. They do have a 72" finish mower available through Rural King (and other places I'm sure.)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2018 Ford Transit 350 (A57148)
2018 Ford Transit...
LOT: (2) Kimball Midwest 4-Drawer Hardware Cabinets, (1) 2-Drawer Hardware Cabinet w/Contents & (A59076)
LOT: (2) Kimball...
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
2013 Chevrolet Express 3500 Passenger Van (A55973)
2013 Chevrolet...
