If You Were To Get A New 6 Ft Finish Mower - What Would You get?
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #81
Most three blade fishes mowers give good results but if you want a really beautiful job from a used finish mower, put on a new set of blades. Amazing results.
   / If You Were To Get A New 6 Ft Finish Mower - What Would You get? #82
I hate spending money but wanted to get a finishing mower for the 4+ acres along and beside the beginning of my long driveway - former pasture. A rotary cutter works, but the area looks rough and I wanted a better look. Finally found an old Howse 5 foot finish mower for $300. It had flat tires, but remarkably little rust. It had been sitting under a farm tree for at least 10 years. Darn thing is heavy as the dickens but, amazingly, the belts are intact and have survived about 8 hours use so far. Surprisingly, I find that parts for this old mower are still available. They may cost a bit, but I can stand that better than paying thousands for a new one.
There are a couple of types of blades for bush hog rotary type cutters, straight blades and curved lifting type blades which lift the grass and leave a much closer nicer cut, I used to have a 6' Howse rotary mower with lifting blades and it would leave a finish cut that would almost rival a finish mower, might be worth checking which type of blades you have on your rotary cutter.
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
Informational Lot - Shipping (A61306)
Informational Lot...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
