IF you own a freezer......
   / IF you own a freezer...... #121
Okay, that is the same model I now have two of. Finicky little buggers but mine are both working great now.
I did add two independent monitors on the freezers with battery units on the outside and corded temp probes that I slipped past the door gasket (very small cable) for double safety. It is one thing to lose a fridge, but a freezer can get expensive. The different units are fairly close reading wise.
   / IF you own a freezer...... #122
I just use the last, as it has served me well for 30 years. I get into the habit of glancing at it regularly. The house freezer doesn't concern me anyways, I hear when it kicks on so know that it's running. When they don't start up or never stop is when you have problems...
   / IF you own a freezer...... #123
One thing the Acurite tells me that I would never have known is the cut-off to cut-in range. I was surprised to see a 20 degree total swing on one and a 15 degree in the other. Better for life of the freezer I guess. Second picture is one of the wired units I installed. I set both to 0 degrees on center.
B97ED36A-48CE-4C12-BB09-BAC3D983A6FB.jpeg 0A584F37-E873-4693-9B9D-ED0CA68C1AF4.jpeg
   / IF you own a freezer...... #124
I will be finished running my 7 day straight with an empty freezer having found a place to tuck it out of the way. I will pick up 15 gallons of distilled water (which I use with coolant) and after freezing and stabilizing the temp for a few days rerun the 7 day test and see if it does use fewer Kwh's.
Freezer is now running with 15 gallons of water jugs frozen and stabilized for four-five days.
   / IF you own a freezer...... #125
Well, y'all convinced me to buy the Accurite temperature monitor. It arrived a couple of days ago and was easy to set up. It's the first time I've seen the cut-in and cut-out temps. The upright has a swing of about 10* and the chest freezer is only 3*.
   / IF you own a freezer...... #126
Congratulations. On the upright is that a Plus 10, minus 10 for 20 total or plus 5, minus 5 for a total of 10?
   / IF you own a freezer...... #127
My freezer monitor is a Taylor brand. Doesn’t take batteries or plug in. Ive got use to glancing at it every time I go by.
Noticed that the temp varies about 12 degrees.
   / IF you own a freezer...... #128
That's hard to say. I have the upright set for -10*, but the Accuride says the coldest is -5*. The temp difference between max and min was 10 degrees when I made the post. It's now at 15* between max & min and BTW it is also a frost free freezer so I expect a big temp swing eventually. It's only been in place for a few days, I figured that after a day or two I'd have an accurate profile on the temperature swings, guess not. Now I'm thinking about a data logger for the temps.
   / IF you own a freezer...... #129
^^^ 15 and 20 degF is what I am seeing (total) on my frost free uprights, so that makes sense. I am sure the contents do not swing in temperature nearly as much as the air.
   / IF you own a freezer...... #130
Probably correct. One more reason to keep those freezers as full as possible.
2016 Ford Fusion (A50324)
2016 Ford Fusion...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
