If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #551
Good idea....thanks
   / If you have Toolcat questions, ask them here... #552
Has anyone removed the black plastic hood/visor at the top/front of the cab that houses the 4 off-road/work lights? I am installing a magnetic rotating beacon and side work lights and want to run the wiring into that covering and down the A pillar to the dash. Has anyone done this? Any tips or pitfalls?
Thanks, DEWFPO
   / If you have Toolcat questions, ask them here... #553
Thanks, DEWFPO
Show pictures when you get it off. I was wondering where the wires for the safety beacon would be.
   / If you have Toolcat questions, ask them here... #554
I had to take mine off at least I tried to get wipers back to top when shut off.. it would be way easier with two people.. have to take inside headliner off in front to access
   / If you have Toolcat questions, ask them here... #555
Hi All,
New here. Been lurking while I was researching to buy.
Just took delivery of a 2007 5600. serial *A0W111290* 800 hrs
Drove it off the truck. Turned it off. signed the paperwork. Started it back up and drove in around.
Woo Hoo. Just what I wanted.
Turned it off.
Came back 10 mins later to put it in the garage and it wont crank.
Getting an error 50-07
F-P-R error.
Yes the selector wand it in the middle.
Dealer I bought it from said to check the fuses, but they all look good.
I purchased a maintenance manual, but it does not include a wiring diagram.
Anyone have any suggestions?
Thanks,
Bob
   / If you have Toolcat questions, ask them here... #556
A 50-07 code will not stop the engine from cranking. Controller is sensing lever is not feeding back a signal. Check relays . Check fuses with a VOLT METER:thumbsup:
   / If you have Toolcat questions, ask them here... #557
Thanks, I will check the fuses again.
How would I check the relays?
   / If you have Toolcat questions, ask them here... #558
Check cab fuse F10. Switch relay with another. Switched power relay R1 powers the F/R lever. Also are all electrical items working with key on? ( heater fan, lights, etc.)
   / If you have Toolcat questions, ask them here... #559
heater fan works, wipers work -no lights (not sure if they work)
All fuses checked with meter.
swapped all relays.
If I unplug the F-P-R lever - no difference.
Once I turn key to start it gives Beep Alarm.
   / If you have Toolcat questions, ask them here... #560
Also fuses are not labeled.
The fuses I am checking are below front of driver seat.
HUSQVARNA RIDING...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
