If you have small acreage and thinking of cutting hay... Drum Mower
   / If you have small acreage and thinking of cutting hay... Drum Mower #61
I didn't know one could buy anything made out of metal for $ .25 cents this day & age especially cutter blades. I wish my Vermeer 7030 only cost that much but they're about $3 apiece
I buy them from Phil in the 100 count box for $25. The ones he sells fit more than his mowers.
He has a WWW. SFI. There are several sites. The first one doesn't work but the second one does. He is not too far from you.
Mark
   / If you have small acreage and thinking of cutting hay... Drum Mower #62
Jim,
I buy Kuhn brand blades from the local tractor dealer and they are $1.40 each. I've found that they last longer than the generic ones.
Last week, we used both mowers to cut 52 acres. I had a set of generic blades on one mower and Kuhn on the other. I had to turn the generic blades over after 40 acres. The Kuhn blades were still good to go. That was the last of the generics. I won't be buying any more of them.
   / If you have small acreage and thinking of cutting hay... Drum Mower #63
The MFGR/number of the blade is SMA 798-RM15
They fit Phil's mowers and also subs for:
NH 495808
Hesston 6616924
Bugatis 147040
Zweegers OM 15
Double sided so that you can use them twice (left drum and then right drum) and tempered.
HTH,
Mark
   / If you have small acreage and thinking of cutting hay... Drum Mower #64
Dave, after a couple of years I was wondering how your drum mower is holding up, as I have just purchased a Galfre 130. Thanks
It's working very well.... I just cut a lodged field of alfalfa/grass... it was flattened pretty good with all the rain and how tall it was before it rained... the only "missed" cuts were where I had to drive over it before cutting....
   / If you have small acreage and thinking of cutting hay... Drum Mower #66
I'm gonna try to ted with my Morra rotary rake. I'll remove the shield panel that normally makes the windrow and see if the hay will just get thown off to that side and sorta spread out. I've had a little trouble picking up with the baler where a windrow was made on top of a cut row that never got swept with the rake and was kinda mashed down in the stubble. My SFI drum mower has been working good, but, I'm gonna be a little more picky about where I buy the replacement blades as those A&I blade wear down too quickly. There's suppose to be a place called Sickle Service that sells a good blade. Has any one had experience with Sickle Service or their blades? bjr
I bought an extra pack of 25 blades and belts from CCM machinery when I ordered my mower.... still using original blades... even hitting rocks etc. I can find no damage on the blades... they are hard, hard, and hard... good quality steel...
   / If you have small acreage and thinking of cutting hay... Drum Mower #68
Hi Dave, I just come across this thread and find it very interesting. I have an older NH 488 haybine, it works good but more costly repairs are certain to come. I will be looking into a drum mower within a few years. Here is a picture of a field I cut last night. It was very thick, but I cut 5 acres in 3 hours. 20150615_190110.jpg20150616_205234_resized.jpg20150616_210110.jpg
The picture you posted to start the thread was picture perfect, awesome field.
   / If you have small acreage and thinking of cutting hay... Drum Mower #69
How you Doin' Dave? I wrote you a PM Did you get it? bjr
YEP... back at yaa....
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
Spirit scooter (A55787)
Spirit scooter...
2001 Bobcat 873 Compact Wheel Loader Skid Steer (A56857)
2001 Bobcat 873...
2016 Isuzu NPR 18ft. Box Truck (A56858)
2016 Isuzu NPR...
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
