If you could only own one
/ If you could only own one #1
rcspott
Montana
2004 Kubota L48 TLB
I need to do a variety of projects, yard leveling, road scraping and beveling, snow removal, etc, and not alot of either but... My question is if you could only own one would you buy a box scraper or rear blade. Note it will be mounted on a L48 Kubota.
thank in advance
rich
/ If you could only own one #2
The grader box!! Why? Because of the weight. The blade is much lighter and will not dig in when you need it to. I tried a blade and found that it bounces along the ground unless you have very loose dirt, or snow. On the other hand,. I have used the grader box to scrape snow for several years. The only drawback is you have to push the snow off to the side when it builds up too much.
With blades in the front and back or the grader box, you can use it for a bulldozer also, when necessary. /forums/images/graemlins/grin.gif
Chris
/ If you could only own one #3
Rich .
Pre supposing that you have an Fel and tooth bar . I'd go for the rear blade. Of course that depends on the blade . I went with the heaviest blade I could get . I also got the optional end plates . Mind you now You asked if I could only own one .
I have snow to consider . And at the time iI purchased I had to make a choice between a rear blade and box blade for financial reasons . John
/ If you could only own one #4
I have both and I never use the rear blade. I suppose if I didn't have a plow I'd use it for snow.
Andy
/ If you could only own one #5
I would go with the boxblade myself.
/ If you could only own one #6
Get the box. I bought a blade and while it is useful I have also rented a box and have really wished I'd bought that. I had the same choice to make and made the wrong decision... /forums/images/graemlins/frown.gif One of these days I'll buy a box scraper and I doubt I'll ever use my blade again after that.
/ If you could only own one #7
Box. no question. In clay, a rear blade is near non productive, even spreading piles. A rear blade also lacks rippers to break up the area one wants to move.
/ If you could only own one #8
I too would buy the boxblade. Midwest bb looks good.
/ If you could only own one #9
Get the boxblade. Make sure it is heavy, very heavy if possible and with a hinged rear blade. I have a rear blade too, and I have not used it in over 6 years.
/ If you could only own one #10
</font><font color="blue" class="small">( One of these days I'll buy a box scraper and I doubt I'll ever use my blade again after that. )</font>
Let's see here...... /forums/images/graemlins/confused.gif
Rich doesn't have anything and is wondering what to buy. Some guys are saying buy a blade, some say a box.
Chris has a blade that he doesn't want and would buy a boxblade. <font color="blue"> Chris - You REALLY should have suggested that Rich get a blade! /forums/images/graemlins/wink.gif </font>
Maybe something could be worked out here?? /forums/images/graemlins/confused.gif /forums/images/graemlins/smirk.gif
/ If you could only own one #12
I've used both, and a boxblade is much more useful because it can accomplish a variety of tasks. A back blade is very useful to distribute loose material, but that's about it. A boxblade can tear up consolidated material with rippers as well as distribute loose stuff. Because it is a box, the material can be moved a long distance without spilling out the sides as well. In a pinch, a box blade, rippers fully extended, can be used to tear up soil for planting food plots for wildlife or even a garden . . . I know because I do it every year. Lastly, if you have a loader, the box blade is usually heavier and more compact than a rear blade, and I think it works much better as a counterbalance.
/ If you could only own one #13
<font color="blue"> Chris has a blade that he doesn't want and would buy a boxblade. Chris - You REALLY should have suggested that Rich get a blade! </font>
Doh! My thinkin' and schemin' cap was definately not on /forums/images/graemlins/grin.gif!
I'd sure be willing to sell off my blade and put the money towards a box (might get the CFO to go for that /forums/images/graemlins/wink.gif), but I doubt it'll work for Rich. I think he has a B24something and would want a 60" blade - mines a 48".
/ If you could only own one #14
If ALL you have is the blade, the box is more useful than the grader blade.
If, however, you have a tiller, and rear scoop or front end loader... the grader blade, for me, has been much more useful for all the things I need a blade to do.
The tiller does a night-and-day better job at breaking up the ground than the box blade and rippers. And the scoop/loader allows you to move the dirt over any intervening barriers, rather than having to drag the material around or across them.
FWIW
/ If you could only own one #15
Yeah, if I had a tiller the rear blade would be a lot more useful. The biggest problem with it is it just can't break up the ground (no scarfiers). And the other thing that often happens with it is if I do get it to take a good "bite" it digs in deep and becomes a "tractor anchor" /forums/images/graemlins/tongue.gif. Maybe if I had float control...but I don't /forums/images/graemlins/frown.gif, and my feathering technique isn't good enough to get a smooth trail.
/ If you could only own one #16
Welcome to TBN! /forums/images/graemlins/smile.gif
Add my voice to the chorus telling you to get a box blade. /forums/images/graemlins/smile.gif I have 60" box blade made by Midwest and couldn't be happier with it. I've used it to maintain my drive and to level some clay mounds and for about everything in between and it's performed flawlessly.
Good luck with whatever you decide. I hope this helps. /forums/images/graemlins/smile.gif
/ If you could only own one #17
As if you need another opinion, Boxblade. John
/ If you could only own one #18
An L48 Kubota has the moxey to pull a heavy blade. The weight makes the difference in what you can do. A light blade can be an exercise in frustration. I use a 176-9 BushHog blade on a Ford 5600. The blade weighs close to 1,400 lbs and is rated for tractors up to 125 hp. Before I bought a blade I looked at what the Ford (60 pto hp) could handle. The tractor can easily wag that blade around and as long as I don't try to shove a 4' high pile all at once, it will do the job and it DOES NOT bounce. The blade turns the Ford into a bulldozer.
With the offset capabilities, I don't have to get down in the ditch. The only thing I regret is that I don't have hydraulic tilt. With a smaller tractor, I say go for the box blade. With the power you have, you can buy a heavy back blade that will work for you.
/ If you could only own one #19
For moving material?
Box blade..
I have a tiller, and I use the box with rippers down before I till a hard packed area. It cuts my tilling time in half for not too much effort.
I have a box and a tiller so have adapted to using them. I suppose it is possible to adapt to using a back blade. I just find the rippers very valuable and the ability to level large areas by carrying a load of dirt across it invaluable.
/ If you could only own one #20
</font><font color="blue" class="small">( Jim ... why do you recommend the rear hinged blade? )</font>
Sorry Doug, I haven't been back to this thread in a few days, and I almost missed your question.
I like the rear hinged blade because it allows the inside blade to get a better bite in loose soil and cut deeper. If the rear blade is fixed, it tends to float the box.
Both my boxblades are hinged and both can be pinned down if needed. When the rear blade is pinned down, it works better for spreading/smoothing material unless that material includes clods of clay. If that's the case, the rear blade will lift the box and you'll get more material released than you intended. /forums/images/graemlins/frown.gif If the rear blade is hinged, a clod or stone just pushes it up out of the way without lifting the box. /forums/images/graemlins/cool.gif
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2013 FORD F250 (A60460)
2013 FORD F250...
PLEASE READ (A63116)
John Deere Cotton Picker Catwalk Floor and Railing (A63116)
John Deere Cotton...
8087 (A61165)
8087 (A61165)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
