If waxing tractor is lame...look what I did
   / If waxing tractor is lame...look what I did #21
Good Point P.L. but I think the difference as you know is Professional v.s. hobbyist.
   / If waxing tractor is lame...look what I did #22
Nice job!..... Oh, I do wax my tractor once a year. :D
I have been thinking about having my mower decks & under my bush-hog sprayed.
I found out some info. today about spraying mower decks.
A guy that does this told me that it might not be good to spray them... Because a rock could make a chip, and then water (might) start getting behind the coating.
He uses a different brand, and told me that if I do this then use the "herculiner" brand, because it won't chip.
   / If waxing tractor is lame...look what I did #23
I'd be looking for something 'Super-Slick" that you could spray apply to a mower deck , but really a snowblower, housing and chute! Gary's "It", just doesn't cut it! Just gotta think, if there was a product that would hold up, they'd already be using it. ~Scotty
Great job, and idea, on the fenders BTW! ~S
   / If waxing tractor is lame...look what I did #24
Lawn companies have had good results with spraying Fluid Film on the underneath of mower decks. I believe it's helped in lessening the amount of grass that sticks. For me as a homeowner though, it's not really that necessary as I just scrap the decks after every use, which might be every 10 days - 2 weeks.
   / If waxing tractor is lame...look what I did #25
I wax my tractor every 11 years. Stlll another 9 months to go for the first wax job.....
   / If waxing tractor is lame...look what I did #26
WH401-I hope you meant to say 'scrape' instead of 'scrap'!! Otherwise let me know where your scrap dealer is located, so I can pick up your rejects! :D ~S
   / If waxing tractor is lame...look what I did #27
I wax my machines at least 3x a year with a dewalt buffer and a commercial cleaner wax called PRO GOLD, it takes 6 minutes to do a tractor.
Well it keeps them looking like new even though they are 20 years old.:D
   / If waxing tractor is lame...look what I did #28
I just did the rear rocker panels on my wife's '02 suburban since rust is beginning to develop. I used Herculiner and it looks great. I'm thinking of doing the area under my floor mat on my tractor since it's been scratched up some and I know water stays trapped between the mat and the deck. I don't want those panels to rust out on me!.
I've thought about doing the wheel wells of the tractor and the suburban too since we have lots of gravel roads around here and they get beat up pretty good.
I'm planning to get a new (used) dually in the next couple of months and will probably do the rocker panels all around as well as the wheel wells on that too.
   / If waxing tractor is lame...look what I did #29
Ah, that would be "scrape" then :D. Replacing a $2500 mower for cutting every 10 days would get costly real fast:eek:.
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
