If I could only have one cutting tool...?
   / If I could only have one cutting tool...? #51
I don't have a torch set or plasma cutter, or even a cheap bandsaw, so I make do with a sawzall. I've used a torch and cutoff saw before and they work well, thought the torch definitly takes a little practice. I find the sawzall works well and maybe requires a slight touch up with a belt sander or file to deburr and thats it. Certainly cheap enough, though I would love to have a plasma cutter for heavier stuff over 1/4" thick.
For some reason, I can't get my sawsall to cut straight. It's a Makita, and I use the Milwaukee ice blades. I've been making do with a 4 1/2" grinder and skinny wheels. I've found that any other cut takes just as much time with a grinder to clean it up as I take with the grinder to make the initial cut.
2025 SDLANCH TRAILED CRUSHER (A58214)
2025 SDLANCH...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
