idle surging problem
   / idle surging problem #1
slamen
barryville ny
new holland l454
Hi I have an older new Holland L 454 skid steer that the idle surges at will . Can some one help guide me to a solution to this problem?
   / idle surging problem #2
What engine? Probably governor adjustment or governor worn out.
Teledyne continental tm 13 gasoline engine
   / idle surging problem #4
On a gas engine idle surges are usually too lean fuel mixture. Sometimes as a quick fix you can access some air bleed jets located in the air stream at the top of the carb by removing the top of the carb and spraying the jets with carb cleaner. For emission reasons most engines have a crankcase vent hose directed into the carb top after the air filter. As the engine gets older and blow by increases this oily air leads to crud building up on the jets. Although contrary to good environmental practice, I remove this hose and run it to the ground. If I am feeling really guilty I put a filter on it to catch the oil and change the filter regularly.
Sometimes a thorough carb cleaning is necessary.
Dave M7040
will check suggestions this week end thanks , will keep you updated
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
1990 Nitro Tracker 165TF Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Tracker...
2015 TOP HAT TRAILER 18 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
