Ideas for improving L3800 for hillside vineyard work?
   / Ideas for improving L3800 for hillside vineyard work? #1
kallnojoy
KY
Kubota L3800
Long story short, I'm trying to determine how reasonable it is to improve an L3800 for hillside (side hill) work within a reasonable budget ( a few/5K).
In other words, how much can the L3800's (4x4 HST, currently with loaded R1s) stability be improved for side hill work without compromising the tractor or wasting dollars.
I presently hog these hills with it and do about 70% across the slope, 30% up/down, always when dry. They are pretty moderately sloped... never measured but easily 20% or > in portions.
If I put in grapes, all work will be side hill though an offsetting factor is that I would groom the hill sides prior to planting, eliminating as many irregularities as possible.
My main concern would be spraying chores and I won't always have the luxury of waiting for things to dry out... would either be a hitch mounted or towed rig.
Other tasks like mowing or any ground engagement work can normally by delayed until things have dried out.
A few ideas I was considering:
1. Lower CG by changing out front/rear wheels/tires to smaller diameter (while maintaining correct ratio since 4x4). Would need help calculating size options and or is it feasible to change gear ratio if need be.
2. Widen stance - 3" wheel spacers on each rear wheel
3. Widen stance - wider rear wheel/tire profile than existing R1s but with similar aggressive tread
4. Add weight - loaded tires, wheel weights, front suitcase weights, fat (short) operator, other? I keep looking at the FELs "subframe" and can't help but think there must be a way to leverage it for some type of low ballast mount.
5. reduce pivot travel of front axle? If that's realistic, would it then be worth while to either widen (or spacers) or load the front tires as well?
And the potentially dumbest, partially formed, half-baked, thought of this while typing the above kinda of idea....
6. if the FEL was on... and the bucket were modified with a wheel on each corner, and the bucket loaded to near lift capacity with a stable ballast... and in the FLOAT position so that the added wheels maintained contact with the ground... would it aid lateral stability, acting as an articulated extension? confused2:
Other suggestions welcomed.
And yes, I'll buy a purpose built machine if necessary.
This notion of adapting the L3800 was inspired in part by "Flusher"'s sexy orchard tractor in this thread: http://www.tractorbynet.com/forums/buying-pricing-comparisons/115967-help-selecting-tractor-steep-brush-6.html
   / Ideas for improving L3800 for hillside vineyard work? #2
I think some one on this forum added rear duals to a small Kubota.That may be your easiest solution.For sure any weight added will help lower the center of gravity,I.E.loaded tires/wheel weights.I don't know if the wheeled FEL idea is good or not.
Another note;by adding wheel spacers you add a little stress on the bearings
   / Ideas for improving L3800 for hillside vineyard work? #3
Not a fan of the loader idea.
To make a tractor stable it must be wide and low. Best to start with a tractor that's wide and low to begin with. Then make wider and lower! Lol
Around here many tractor run rear duals with wheels pushed out all the way. Front and rear. Also need 4wd of course. I'd weight tires only to axle center line... Only rear tires. Then you also may add suit case weights to rear axle or rear of chassis... Low.
The tractor pictured above is a perfect example of a hill tractor.
Also you don't want to lock front pivot. Tractor will be more unstable and loose traction.
   / Ideas for improving L3800 for hillside vineyard work? #4
I put duals both front and rear on my L2800 for flotation on the beach. The sidehill stability was a huge side benefit that was worth the cost of the extra tires n rims alone as I am almost never on the flat although I am creating more:)
I got my rears from unverferth.com but had to make my fronts for it, although just for stability all you would need are the rears.
   / Ideas for improving L3800 for hillside vineyard work? #5
I think locking the front pivot would be a big mistake. If the front goes over a hump, it will have to lift the other front up in the air or the same side rear. Give weights and fluid, most likely the front. But that is bound to cause more twist on the tractor frame no matter how it is applied. The idea of using the fel with outboard wheels is rather unique, but unless it is in a locked position, it isn't going to help much. It's going to have to be float unless you have absolutely angular hills. Any weight out front of the wheels is removing weight from the wide, stable rear and putting it on the floppy front end.
I love the duals idea. You move the pivot point out another foot or more and add a few hundred pounds on the top side with fluid in the far outside.
   / Ideas for improving L3800 for hillside vineyard work? #6
Rick, Do you by chance have any pictures? If not do you have r-4 or r-1 tires? I would like to have duals on my 3700.
   / Ideas for improving L3800 for hillside vineyard work? #7
I think you're better off to look for a different tractor. The L series are relatively high and narrow to begin with, mine is no treat on a side hill. I'm pretty sure Kubota doesn't recommend duals on the L3800. It says in my owner's manual that the L3400 isn't approved for dual wheels either.
Sean
   / Ideas for improving L3800 for hillside vineyard work? #8
I just went and snapped these, if you do a search on my posts you can see other pics I have taken of them. I filled the inner tire originally with rv anitfreeze but have since drained it out as I didnt need the extra weight and as I transport the tractor in a skiff at times the weight is a real penalty. I definitely need a bigger tractor and have probably over worked this one but as this is as big a one I can fit on my boat this is what I have. I did develop some cracks on the inner wheel disc on the rear wheel and if you look carefully you can see where I welded in a reinforcing disc, only had the problem on one side and I have still not gotten around to welding in the disc for the other side even tho it has been sitting there waiting for a couple years, havent needed it. It was not recommended to put duals on this tractor btw, but it would be worthless to me without them and I have no regrets doing it.
   / Ideas for improving L3800 for hillside vineyard work? #9
20 percent is steep. Go slow bro. Go slow. A pull behind spray can go sideways fast and then so will you
Thanks for all the replies and suggestions so far.
I was initially considering duals, and still may, but had a few concerns:
- Overall width may be too wide for the planned row spacing
- void warranty at best and at worst break stuff (or wear prematurely)
- doesn't address the height of the tractor
- reduction in traction
My first inclination is still the low/heavy/wide idea of:
lower the tractor by going with smaller diameter wheels & tires to get the ride height down.
Ideally at the same time going with a wider tire profile and/or spacers to increase the rear footprint.
Pack on as much weight wherever it can be done safely and be of help.
I just don't know how much I can reduce the tire sizes and if that change would be of enough magnitude to be worth the effort.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
