Ideas for cannon ball extraction?
   / Ideas for cannon ball extraction? #121
How about liquid nitrogen poured into the ignition hole? The ball's mass would shrink faster than the cannon bore and may slip right out.
   / Ideas for cannon ball extraction? #122
Now we're getting down to the cold hard facts!
   / Ideas for cannon ball extraction? #123
I'm just here to say that "I inherited a cannon", not something you hear every day. Is the powder breach loaded? If not, hell charge it up and fire that effer! That will free that ball...or mushroom out the barrel, send shrapnel flying everywhere, just epic!
   / Ideas for cannon ball extraction? #124
Okay, I get it the expanding foam / insulating foam (we have used it at the back door to seal off drafts) is a bad idea. Fair point.
:) Yet the ball is still in there, and at one point it seemed to me like a possible option to aide in the problem solving. Oh well.
Yea, that’s a terrible idea. That stuff is horrible to clean up and it wouldn’t work anyway. It doesn’t make a lot of psi expanding.
I wasn't at all thinking of PSI or the clean-up mess ... I was thinking of it as a seal to produce suction and hopefully continue to inch the ball along, as it was moving at one point.
it is likely stuck in the gunk / blemishes behind it, rather than the gunk in front of it
What got me to thinking about expanding type foam is the stuff they inject under concrete slabs to raise and level.
bingo - expansion and loosen
still a bad idea, at this point
   / Ideas for cannon ball extraction? #125
Big rope over a tree and tow it up with the tractor and drop it on the end of the barrel on some concrete. I'm sure that woud jar it out real quick. Take the barrel off the carriage first.
   / Ideas for cannon ball extraction? #126
The problem with the many "drop it on the muzzle" suggestions is if whatever is interfering with the ball doesn't give way, the contour of the ball at its equator cause significant wedging forces.
   / Ideas for cannon ball extraction? #127
Since the op has drilled into the lead ball threading in a coarse lag screw should give a point to pull from.
If excitement is wanted a little gasoline or propane down the ignition hole with a long fuse may be considered!!
   / Ideas for cannon ball extraction? #128
This thread is worthless without excitement!! :eek:
   / Ideas for cannon ball extraction? #129
I think it's an iron ball which was either used to blast through the wooden sides of a ship or was supposed to bounce off the ground to kill or maim anybody in its path.
I searched the question of how to remove a stuck cannonball to compare the results against the ideas posted here.
None of it as was interesting as this thread.
What I read elsewhere said it only takes a little propellant to send the ball flying. That's a lawsuit waiting to happen.
   / Ideas for cannon ball extraction? #130
I originally thought it was an iron ball as well, however, looking at the photos on post #109. I don't think so anymore. He's using a hand drill with a wood cutting bit with an auger threaded point. To get metal shavings like that, it's more likely lead. If nothing else, he can hang it with muzzle pointed down and melt out the ball. - That means he'll end up with the barrel coated with lead and will have to use bore cleaner to get it all out afterwards.
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2025 Kivel Quick Hitch Skid Steer Attachment (A55851)
2025 Kivel Quick...
DIRT DOG CLR60 60" RAKE (A57192)
DIRT DOG CLR60 60"...
2014 Ford Mustang Coupe (A55853)
2014 Ford Mustang...
UNUSED FUTURE FT-GR87 87" HYD GRADER (A57193)
UNUSED FUTURE...
2015 Jeep Cherokee Latitude SUV (A53424)
2015 Jeep Cherokee...
