Idea - mini receiver hitch
/ Idea - mini receiver hitch #1
dillo99
Upstate NY
Kubota B7500
So I got this idea today. /forums/images/graemlins/laugh.gif
I keep a backhoe and a loader on my K B7500 pretty much all the time so I am constantly trying to figure out ways to carry other stuff (don't want to take off the backhoe/put on a carry-all, etc.). So I am planning to make a few things that I can attach - a chain holder, a chain saw holder, a gas can holder (for chain saw), toolbox, etc. BUT I keep wondering about where to attach this stuff - and I'm not sure I want it all to be permanent. So here is the idea....
I am thinking that I will make all of this stuff with 1" square tubing as the attachment point and then have these mini 1" receivers in a variety of locations. I can have one on each side of the ROPS, and two on each side of the FEL frame (one high and one low) and one on the front grill. That gives me seven places to "plug in" these attachments and carriers. MORE THAN ENOUGH.
Now you might ask why not just use a regular receiver hitch - but I really don't need all that strength nor do I need to take up that much space. These things are 25-50 lb items so I don't need the strength of 2" receiver or even a 1.5". By using a smaller receiver it is easy to tuck these things into tight places. I am even considering that I would add a few mounts to my ATV and thus allow the transfer of these carriers to the ATV. This would be handy for the chain saw carrier for sure.
So what do you think? Anyone ever done something like this?
Attachment ideas:
* Chain saw clamp (holds the bar)
* Shallow "pan" to hold gas can (for chain saw)
* Shovel/Rake rack with a low part (attaches to low receiver on FEL) that receives the ends of the tools and a high part (attaches to the high receiver on the FEL) that clamps in the top of the tool.
* Toolbox
* Chain box
* Cellphone/cup holder
Mike
/ Idea - mini receiver hitch #2
Sounds pretty clever to me, and appreciate the tip. I will be looking at places to 'stick' these receivers, and hope you won't mind the 'theft' of your great idea. /forums/images/graemlins/wink.gif
Right off the bat, is the one with a vise for holding things such as the chainsaw bar for sharpening the chain. In fact, it may just as well be used to transport the chainsaw at the same time.
I can think of one on each side of the iMatch, as I go logging I throw the tongs on it, and it could also be used with your idea to carry gas, chainsaw, chain, etc. with two of your receivers.
I like it!!!
Great idea on the vice attachment. I could see that being very handy.
Glad to have you borrow the idea of the mini receiver. I have sketched out a few of the attachments and will probably draw them a little nicer and then post the sketches here later in the week.
/ Idea - mini receiver hitch #4
I really like your idea too and can think of a few things to use them for. Are you planning on using 16ga x 1-1/4" sq tube for the receivers?
Here's my quick solution to hauling stuff around ... I can even get my 2kw Honda generator on it with room to spare.
Cheers!
/ Idea - mini receiver hitch #5
I have a boom pole/trailer mover that I've attached various things to. I pull out the boom pole and insert my rock mover. I also have a pallet mover that works the same way.
I like the idea of expanding the concept to various other quick mounts.
I'd use 1.25" small receiver hitches as you can find a bunch of standard stuff to build onto. Everything will be predrilled for pins and the like.
/ Idea - mini receiver hitch #6
Homebrew2
That is a great hood protector too, and has a tremendous capacity for hauling things.
At first I didn't like it, because it covered the hood which looks great (I like green best though /forums/images/graemlins/wink.gif ). But on second thought, it's a great idea. Especially for the woods trips where the biggest fear is the reality that something can come down on the hood to do some damage.
Great idea.
/ Idea - mini receiver hitch #7
</font><font color="blue" class="small">( So what do you think? Anyone ever done something like this? )</font>
Check out Arctic Cat Atv's MRP system. Similar to your idea and may give you some new ideas.
Home Brew,
I like the hood storage. I considered something like that - looks like a great way to haul stuff.
Regarding the receivers, I had not figured out what size just yet. Could use 1.25" tubing and 1" square tube or square rods on the attachments. Or could possibly go smaller - 1" tube with 3/4" rods.
DIY GUY,
I have thought about using the 1.25" size so standard stuff might fit....I would not use the actual receivers - would rather make my own (don't need chain hooks and all that stuff that takes up more space). I'll have to measure a receiver - I assume the inside dimension is 1.25 vs. the outside dimension. Most square steel tubing is the other way around - sold in outside diameter sizes. I'll need to go do some measuring.
BowHunter,
Thanks for the tip on the Artic Cat ATV system. They call it the "speed rack" and it is definitely the same idea - plugable rack components. There is some interesting stuff there. If it wasn't so pricey I might consider engineering my system to receive those components...can't quite see what the "receivers" are on the web site.
Thanks all for the feedback and thoughts. I'm going to do some further research on this and see where I end up. I'll keep you posted!!!
/ Idea - mini receiver hitch #9
Dillo99,
when you get it all figured out, don't forget to get a design patent, and start manufacturing them for the rest of us! Sounds like a healthy market!!!
/ Idea - mini receiver hitch #10
</font><font color="blue" class="small">( That is a great hood protector too, and has a tremendous capacity for hauling things.
At first I didn't like it, because it covered the hood which looks great (I like green best though ). But on second thought, it's a great idea. Especially for the woods trips where the biggest fear is the reality that something can come down on the hood to do some damage. )</font>
Not to mention, the trip to the garden, a place to stick dem 'maters n peppers n corn n...mmmmm.
/ Idea - mini receiver hitch #12
I have been using that concept for years. I have them on my log splitter, which has an electric winch on a swinging boom to lift large chunks onto the splitter. Works well. Both the winch and battery box are mounted on stubs. That way I can use the winch on other machines. I also have some on trailers for tongue jacks to use a stabilizers and such. All my trailers have a removeable hitch which makes them a bit harder to steal and I can change from a ball hitch to a pin hitch in a snap.
Good idea.
Ben
/ Idea - mini receiver hitch #13
I have mounted "receivers" like you are talking about . I have been dealing in Grey tractors for a few years and have a stock pile of PTO shaft that I have cut to length for various implements. It is 3 sided. I weld a piece on to the scaffold and the mate on what ever I need to attach. It is a good fit and won't turn. A hole and bolt and it is locked in. It is light but strong.
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 KENWORTH T680...
Back Buddy (A64194)
Back Buddy (A64194)
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
