Idea for something round to cap a piece of 1 1/2" pipe with
   / Idea for something round to cap a piece of 1 1/2" pipe with #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
looking to make a pipe edge for my plow blade, so on the ends, to keep it from digging in, I want to cap it with a ball , so racking my memory what I can source, like what they might cap a stair railing with..
Any ideas ??thx
I see these, have to find them in Canada or in Fl//
Otherwise.I;m taking a piece of 1/8th flat plate from I have, lay it over a piece of pipe,cherry it up, and lay a trailer ball over it and a couple wacks with Mr 5LB hammer
   / Idea for something round to cap a piece of 1 1/2" pipe with #4
Go to your local hardware store, buy a black iron pipe cap of about the same outside diameter as your pipe, and weld it on.
Look around-some are more rounded than others.
Bruce
   / Idea for something round to cap a piece of 1 1/2" pipe with #5
If you have any fencing contractors around that do ornamental iron work, I'd check with them. They might have some on hand, it would be cheaper getting them from them as King has some pretty high shipping rates, if I recall correctly.
   / Idea for something round to cap a piece of 1 1/2" pipe with #6
Bruce
BCP,
Those look like threaded malleable iron (closer to cast iron than the mild steel pipe) caps. they do not weld well to mild steel and any little force will break the weld apart. Steel caps capable of butt welding to the pipe are pretty spendy and not available in the retail market only at pipe supply wholesalers.
If that is the OP's solution he should consider bronze welding with a torch.
Ron
   / Idea for something round to cap a piece of 1 1/2" pipe with #7
I'd do what Dave said, easy with angle grinder and cutoff blade. You'd be done in half the time than it takes to research & order & receive a round cap. Good description (orange peel)!
   / Idea for something round to cap a piece of 1 1/2" pipe with #9
Cut the top half off of a trailer ball, then cut the shank off the other half? Should be easy with a chop saw. Wouldn't be a perfect dome, but should be adequate for what you need, and plenty strong.
   / Idea for something round to cap a piece of 1 1/2" pipe with #10
If any of you guys are interested, here is a little more detail on orange peel.
2017 Hammerhead Off-Road Utility Cart (A51691)
2017 Hammerhead...
AGT Air Compressor (A50123)
AGT Air Compressor...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
