Idea for an ice scarifier
   / Idea for an ice scarifier #11
I second that. Using a disc is great. Just make sure it is heavy enough to penetrate the ice.
Little screws won't do anything substantial on ice.
   / Idea for an ice scarifier #12
[video]https://www.google.ca/search?q=scarifier+cutting+edge&client=safari&hl=en-ca&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiizdfalYPnAhXGmeAKHZncAqIQ_AUoAnoECAwQB A&biw=1483&bih=970&dpr=2#imgrc=9U6TZyAtXmQZYM:[/video]
   / Idea for an ice scarifier #13
We have a set made by a company called Sanvik. They work great. They cost $300 p/ft. A bit pricey to clean up a driveway. But very effective.
   / Idea for an ice scarifier #14
Get yourself a Rotary Hoe. This is a non-powered pull behind cultivation tool. If you haven"t seen one then Google it.
   / Idea for an ice scarifier #15
I have two, 3-point, implements with scarifiers. LPGS & ROBB. With the scarifiers extended both work fine on ice.
   / Idea for an ice scarifier #16
I have been looking at a home made scarifier using snowmobile carbide tips or self tapping screws . I do not have a huge area to address...maybe an acre total. Using the full 72" FEL width may not get enough pressure on the studs. Considering using 1/4x20 self tapping screws about 2-3" apart on a length of 48" angle iron. The angle iron would be mounted to a SSQA plate and screws would go through the angle iron with the tips protruding onto the ice.
I get ice two to three times a year. Even if I had to replace the screws every time, it would take less than 5 minutes, cost less than $10, and still be viable for my needs.
Has anyone done something like this or have a better idea?
This is exactly what I have been considering. Being cheap, the studs are too expensive and I wasn't sure about the life of screws. Has anyone actually tried using screws yet. I just want to remove the glaze from the ice to make it safe to walk on. I have about 300 lineal feet of drive and only need to do this a few times each year.
   / Idea for an ice scarifier #17
What I have for this purpose is two sections of diamond/spike tooth harrow sections welded together with a hitch attachment. I mostly use this implement for harrowing my driveway but when I have ice I run it in reverse and cut shallow groves in the ice. Reverse because the rear edge is sharper than the front and it does a better job. The shavings freeze on top of the ice and I have a slip free surface. Google diamond or spike tooth harrow and pick out an idea that works for you.
I looked for a while but really couldn't find a complete diamond tooth harrow section online. The harrows come with these teeth. Harrow Teeth. Peavey Mart is an Alberta Canada store but I couldn't find anything similar in the US.
   / Idea for an ice scarifier #18
Go to your local public works dept. they may use scarifier cutting edges on a road grader blade. They get wore out, but there’d be tons of meat left for your purpose. And they are heavy!
   / Idea for an ice scarifier #19
I built one a couple years ago as we end up with lots of ice on the drive and parking area even in the horse pen . Just used metal i had around as I wasn't sure it would work and didn't want to spend a pile of money. I used old ferrier rasps some were a little more brittle and snapped, i replaced those with 3/8 " stock those wore a little quicker tho. It just slips over the cutting edge and 4 3/8 " bolts to hold it in place. I just put a little pressure and back blade .
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
