Idea for an ice scarifier
   / Idea for an ice scarifier #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I have been looking at a home made scarifier using snowmobile carbide tips or self tapping screws . I do not have a huge area to address...maybe an acre total. Using the full 72" FEL width may not get enough pressure on the studs. Considering using 1/4x20 self tapping screws about 2-3" apart on a length of 48" angle iron. The angle iron would be mounted to a SSQA plate and screws would go through the angle iron with the tips protruding onto the ice.
I get ice two to three times a year. Even if I had to replace the screws every time, it would take less than 5 minutes, cost less than $10, and still be viable for my needs.
Has anyone done something like this or have a better idea?
   / Idea for an ice scarifier #2
If you’re just trying to crack the ice to give it a head start on melting (versus scrapping up all the ice), usually driving iver it eith chsins on your tires will be enough to crack it or grind it down
   / Idea for an ice scarifier #3
That would be a lot of broke off screws for the tires to pickup.
   / Idea for an ice scarifier #4
I get a lot of icing here. I use my box blade with the scarifiers fully extended. I am satisfied with the results.
   / Idea for an ice scarifier #6
Scarifiers on your box blade work. Also check out the Rachet Rake in the TBN store. Ratchet Rake
I'll bet it would do a number on ice. I've been thinking about buying one and welding on some tabs so that I can bolt it directly to the bucket.
   / Idea for an ice scarifier #7
I don't think screws would work that great but I know of a number of municipalities that use these both on ice and for grading gravel roads in the summer. Just remember that granite stone and gravel don't work well with these.
Blades
   / Idea for an ice scarifier #8
I used 4x4x3/8 angle 48 in long , Drilled 1/2 in holes every 3 in welded 3 in long by 1/2 rebar pins in angle and mounted on 3pth. I have a square frame for my 3pth. a trailer hitch tube socket .4 in pockets to slide my forks in or a straight back blade short pieces of grader blade for weight used on my b2100 when needed. I also use a frt snowblower I made this 2 winters ago works ok for what I do no pavement. probably last the rest of my life Ken
Never considered the screws would break off. If I only have them protrude 1/2”, they should be relatively stiff and resistant to breaking.
I am not trying to remove ice, just scratch it up to make it safer to walk and drive on. I will give it a try and report back.
   / Idea for an ice scarifier #10
I had a large diameter, 3ph four disk, offfset disk for this purpose. Maybe 30" disks. It scratched up ice nicely. Unfortunately, a cotter pin fell out causing the axle to come off one end and bust the bearing casting on the other side, so I junked it. Disks are quite amazing in their agressiveness.
2020 DRAGON ESP...
Eagle Weathervane (A55853)
Eagle Weathervane...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
