Idea for an ice scarifier
   / Idea for an ice scarifier #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
I have been looking at a home made scarifier using snowmobile carbide tips or self tapping screws . I do not have a huge area to address...maybe an acre total. Using the full 72" FEL width may not get enough pressure on the studs. Considering using 1/4x20 self tapping screws about 2-3" apart on a length of 48" angle iron. The angle iron would be mounted to a SSQA plate and screws would go through the angle iron with the tips protruding onto the ice.
I get ice two to three times a year. Even if I had to replace the screws every time, it would take less than 5 minutes, cost less than $10, and still be viable for my needs.
Has anyone done something like this or have a better idea?
   / Idea for an ice scarifier #2
If you’re just trying to crack the ice to give it a head start on melting (versus scrapping up all the ice), usually driving iver it eith chsins on your tires will be enough to crack it or grind it down
   / Idea for an ice scarifier #3
That would be a lot of broke off screws for the tires to pickup.
   / Idea for an ice scarifier #4
I get a lot of icing here. I use my box blade with the scarifiers fully extended. I am satisfied with the results.
   / Idea for an ice scarifier #6
Scarifiers on your box blade work. Also check out the Rachet Rake in the TBN store. Ratchet Rake
I'll bet it would do a number on ice. I've been thinking about buying one and welding on some tabs so that I can bolt it directly to the bucket.
   / Idea for an ice scarifier #7
I don't think screws would work that great but I know of a number of municipalities that use these both on ice and for grading gravel roads in the summer. Just remember that granite stone and gravel don't work well with these.
Blades
   / Idea for an ice scarifier #8
I used 4x4x3/8 angle 48 in long , Drilled 1/2 in holes every 3 in welded 3 in long by 1/2 rebar pins in angle and mounted on 3pth. I have a square frame for my 3pth. a trailer hitch tube socket .4 in pockets to slide my forks in or a straight back blade short pieces of grader blade for weight used on my b2100 when needed. I also use a frt snowblower I made this 2 winters ago works ok for what I do no pavement. probably last the rest of my life Ken
Never considered the screws would break off. If I only have them protrude 1/2”, they should be relatively stiff and resistant to breaking.
I am not trying to remove ice, just scratch it up to make it safer to walk and drive on. I will give it a try and report back.
   / Idea for an ice scarifier #10
I had a large diameter, 3ph four disk, offfset disk for this purpose. Maybe 30" disks. It scratched up ice nicely. Unfortunately, a cotter pin fell out causing the axle to come off one end and bust the bearing casting on the other side, so I junked it. Disks are quite amazing in their agressiveness.
(3) Skid Steer Tracks (A44502)
(3) Skid Steer...
2017 FREIGHTLINER CASCADIA DAYCAB (A45046)
2017 FREIGHTLINER...
2021 Jeep Grand Cherokee L Limited SUV (A42744)
2021 Jeep Grand...
2012 PEERLESS HYDRATION TRAILER (A45333)
2012 PEERLESS...
2016 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A45046)
2016 GENIE GS-2632...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
