Well, here is my back and forth with Cub Cadet technical dept....
ME......
I recently purchased a new Cub Cadet i1046. The gas pedal is VERY hard to hold down and the tractor runs slow. The gas pedal is the biggest problem. I have heard the 2008 model's have had a design change. Can you advise me on this problem as it is bad enough that I plan returning the mower if I can't get this fixed.
I purchased this mower from Greensboro Tractor in Greensboro NC.
Thank you
Cub Cadet rep......
We apologize, but that issue would be difficult to diagnose via the Internet. We have not experienced similar complaints and suggest you contact xxxxxxx and have them inspect the tractor.
We do not get into lengthy service diagnosis or explanations via e-mail. Our responsibility here in e-correspondence is to respond to the most common inquiries. If issues are too complex or require extensive diagnosis, customers are directed in the manner that can assist them most efficiently.
Me.....
It must be something to my gas pedal problem on my i1046, because I have been told that the 2008 lineup, the pedal and been completely re configured.
Cub Cadet rep....
Again, there has not been a change to the "gas" (actually it is the transmission control) pedal function. Please contact your dealer for further assistance. There is nothing we can do for you over the Inter Net. If you believe there is a problem, a dealer must inspect the unit for you to determine the cause or if the machine is operating as designed.
Well, off to the dealer I go.....
