I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #1
plong1234
AGCO ST28
I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. The battery is brand new and all other electrical works as it should. Please help.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #2
Clean the electrical connections from the battery to the chassis ground and to the starter. Clean and bright.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #3
Everything in neutral or off so that no safety systems are preventing it from starting?
it died right when I was lifting a heavy piece of concrete with the loader and then it was just dead. It is in neutral and everything appears to be off otherwise.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #5
Did you by chance bump a PTO lever or switch? On my tractor this will prevent starting.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #6
do you have power to the starter solenoid when you try to start? it that the clicking sound you hear?
if so try a couple solid taps to the starter with a hammer.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #7
Even though the battery was new, I wonder if your alternator is bad and was not charging the battery, and both are now dead.
I say this from personal experience…….
So - check your battery voltage to make sure it has not died.
it clicks even with the brand new battery. i'm going to check the starter and solenoid next. Tonight when I get home.
   / I was using my Agco ST28 loader and I stalled the engine. Now it only clicks when I turn the key. #10
One more suggestion- maybe check your fuses first in case it’s a simple blown fuse.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2007 Ford F750 (A55973)
2007 Ford F750...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
More info coming soon! (A55851)
More info coming...
