I want to buy a yanmar, need help on HP
   / I want to buy a yanmar, need help on HP #1
bbfarmer
Hello,
I am new here. I have read some of the posts & think you have some knowledgeable people here. I am hoping someone would take the time to
try to help me out. I am looking to get a yanmar & want to get the proper HP for my needs. I want to get enough HP to operate a 5' tiller, 5' bush hog, & a single or preferably a double bottom plow. I don't want to get one that will just handle this equipment & overwork the tractor. I am located in west central texas, my land is flat, & the soil is fairly good no large rocks.
Thank you for any & all input...bbfarmer...aka,confused.
   / I want to buy a yanmar, need help on HP #2
If you are going to pull a double bottom plow . get a 3110 D.
Thanks gizmo! What about a single plow?
   / I want to buy a yanmar, need help on HP #4
I say still get 3110d with ps. But ,then I'm not a farmer . Better listen to the Giz:D
   / I want to buy a yanmar, need help on HP #5
I believe something in the 20-25 hp would be more than adequate for what he listed. a 2210 or 2610 would be good choices, IMHO.;)
Mike
   / I want to buy a yanmar, need help on HP #6
Welcome bbfarmer,
I'm not familiar with plowing but aside from that, the best value is in a YM2210. Listen to Gizmo though, he has first-hand experience with several models.
Bruce
   / I want to buy a yanmar, need help on HP #7
Mike
I have a YMG2000D with 23hp (+/-) Will it pull a double bottom plow through unworked dirt?
   / I want to buy a yanmar, need help on HP #8
I have 24 hp (20 pto hp) and that's not enough for the ground-engaging tasks described here. I think the next size up (2210??) would be working real hard with a double bottom plow so the next step above that would be the minimum for what the OP wants.
   / I want to buy a yanmar, need help on HP #9
tony123 I have the same tractor that you do and I don't think that it would pull a double bottom plow. It is more a weight thing than a horsepower thing. When I stop the tractor with a implement it does not lift the front end but spins the tires. I have a pretty good size grey topped weight on the seat but no other weight. To pull a 2 bottom you would need to add weight to back of tractor (filled tires or wheel weights). I have a FEL that added weight to tractor but not to rear. I thought that I did not need loader untill I got one and now can't do with out. big dan
   / I want to buy a yanmar, need help on HP #10
A 2210 will pull double bottom plow if you load the back tires . And have the right plow and it set up right. but if you hit hard ground it is going to spin . Because you are not going to have the weight you need.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2015 Chrysler 200 Sedan (A53117)
2015 Chrysler 200...
1988 International 1654LP Flatbed Truck (A53117)
1988 International...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
23 Misc Chairs (A51695)
23 Misc Chairs...
