I want a sawmill
/ I want a sawmill #22
A friend built the lifting beam, An gave me the winch for it, Army Grunt
I like your log turner set-up, it was something I had in mind. recently i found using a hi lift/sheepherders jack works but a bit time consuming and more potential for pain :D
/ I want a sawmill #23
Without it I would be sunk.It unloads the trailer,Places the log,Then turns it. Then if you have cut (as I just have in the last few days)3x10x18ft.there for the back poach.Really heavy. Just sling them an off you go:)
I just watched a movie another guy posted. Strangely you never see all the struggling that one will go through getting say a 14" log 12 ft long in place that will if pine weight in at 600lbs. once you get it to a "cant" even using a peeve or cant, its really hard on anyone. (I am not saying it cant be done , but it really takes the "This is fun"out of it.Alaska mills work,But so does a hand saw:)
Ill take a pic after supper of the 3 buys i have sawn.
Army Grunt
/ I want a sawmill #24
Here is a few pics of the 3x10s an the wavy edge siding to finish off my barn.
Army Grunt
/ I want a sawmill #25
Army Grunt
:thumbsup: turning a large cant is a pain, I have a mini excavator works great. I find one of my bigger pains is dealing with all the slab wood. It doesn't seem like much until the end of the day. I use most of ours to heat the better halfs hot tub, or out door fires.
/ I want a sawmill #26
I bought my Lumbermate mill used (barely) for $1200, not a production mill, but I love it for what I do. :D:confused2::laughing::thumbsup:
/ I want a sawmill #27
(((((((((((((adirondacks)))))))))))<-<<that sounds cold!!!headen your way tomorrow. going to Ct.For a week or so.
I use my slabs for boy scout camp outs they like bond fires:)
Army Grunt
/ I want a sawmill #28
Army grunt; we've still got more then a foot of snow on the ground, and the temps are suppose to drop for the next couple of days, CT shouldn't be to bad.
/ I want a sawmill #29
Its been 70s&80 for over a week now:)
Army GRUNT
/ I want a sawmill #30
Got my wife's permission 3 yrs. ago. Got a Woodmizer LT10. All manual but nice mill for hobby and occasional use. Can go to 24" and 11' length. More w/ extension.
Mine was a demo., but still paid close to $4,000.
Have cut poplar, white & red oak and hickory. Mine is a little underpowered, they now have a 10 hp engine on it I believe.
/ I want a sawmill #31
I finished one project - tiller transfer case - and now I am thinking about the old mower motor I have.
It is 20hp twin gas engine, but it has a vertical shaft - could it be used for bandmill? I will have to do right angle transfer - I am sure the motor would not like to have the oil pan on the side:)
What do you think?
/ I want a sawmill #32
Long belt drive should work.:D
A differential with one axle fixed might work even better.:):)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2014 Freightliner Bucket Truck (A61306)
2014 Freightliner...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
24in pin on tooth excavator bucket (A61306)
24in pin on tooth...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
