I thought I'd seen it all.....
/ I thought I'd seen it all..... #1
CAgnoli
Kiantone, NY
Kubota Grand L 3940 HST-3
I'm not sure if I got the picture attached, but this is a friend of a friend who was apparently transporting a load too heavy for his 2305 without a ballast box.....:)
/ I thought I'd seen it all..... #3
Ah the physics of load balancing… by the bye was your friend wearing his seat belt?
/ I thought I'd seen it all..... #4
If he wasn't, he is probably laying out of the picture to the right!;)
/ I thought I'd seen it all..... #5
Hahaha.... the friend isn't in the picture as he went in to clean out his shorts!!
The 2000 series are barely larger than lawnmowers; I'm surprised we don't see more of these pictures given the types of stuff their owners put them through on this board. (I'm used to full size tractors & backhoes, so my 970 seems pretty dinky to me.) Then again, it is a testament to the quality of the units if they hold up to this abuse.
/ I thought I'd seen it all..... #6
Yikes!! I don't know about that series of J-D's, but my 955's front brakes don't work if the 4wd isn't engaged, so, if you're hauling a bit more weight than you should in 2 wd and the rear wheels come off the ground, the brakes don't work. Now THAT gets your attention.
/ I thought I'd seen it all..... #8
Another great reason to keep a loaded bucket low during transport. From the looks of it, his bucket had to be 5' or 6' off the ground?
/ I thought I'd seen it all..... #9
3RRL,
That was my thought immediately when I saw the post, traveling with a load well off the ground, hit a dip and it flipped towards the front. If this is the case, be sure to tell your friend, if transporting weight to keep it very low/almost against the ground. Alternatively, if he had tried to turn with a load transporting it well above the ground, then the picture would have been of that new 2305 on it's side.
I sure hope he has learned a valuable lesson about the need for BALLAST :eek:
/ I thought I'd seen it all..... #11
I think someone was lucky. Perhaps from here on in he will practice safe work rules and pay attention to ballasting . . . I would also play the lottery, who knows, we might have a winner here.
/ I thought I'd seen it all..... #12
Egon said:
Ahh -- It's a posed photo.:D
my impression as well..... if were gonna do that - I think it woulda have done it when first scooping the load --- still ... pretty funny...
/ I thought I'd seen it all..... #13
At 50-hours, that position would make it handy for tranny service. :D
/ I thought I'd seen it all..... #14
I agree it looks staged. It does go to show just how front heavy smaller tractors are with the loader. My 4010 would probably do the same thing easily, though I don't want to try it!
2021 Gulf Stream Kingsport T/A Travel Trailer (A61569)
2021 Gulf Stream...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
Towable Hydraulic pump (A61567)
Towable Hydraulic...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
