I think iI screwed my yanmar govenor
   / I think iI screwed my yanmar govenor #1
bootlegger
i have a yanmar 2000, the injector pump was only pumping on one side. I wasnt sure about what i was doing, so i took the 2 nuts, and the two bolts out of the pump and attempted to take out the pump. Well i found out it does not come out that easy, so i put it back together, and started it up, when i did it tried to run away with itself. Could i have done somthing with the govenor???
   / I think iI screwed my yanmar govenor #2
I think your OK.
You probably missed the pin on the slider that fits into a small "Y" shaped link (under the injection pump). I find it easier to remove the inspection cover off the side of the hydraulic pump and, with a flashlight, reset the pump into the Y link. I'm sure you are either on one side or the other and not exactly in the center.
Mark
   / I think iI screwed my yanmar govenor #3
To remove the pump remove the cover on the from the fuel pump box ( 6 screws ) then reach in and remove the snap pin & spacer from the rack, be sure not to drop the spacer. Next remove the bolts & nuts from the pump, pull out a little bit and turn so the notch in the block will let you remove the pump. Why do you think the pump is not working?
Danny
thanks for the info, i got fixed. I had only one side of the pump working. but i have bigger problems now. the pto is staying engaged, the liget makes a noise and the rear end acts like it trying to lock up.
   / I think iI screwed my yanmar govenor #5
More info, (or better explanation) needed. Are you saying nothing happens when you move the pto shift lever? What is a "liget"? Are you saying the diff lock is engaging by itself or it is trying to seize up?
the pto is staying engaged at all times, the lift makes a noise when when raising amd lowering,and the rear end acts like it trying to lock up.
Gulf Sign (A51694)
Gulf Sign (A51694)
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
