I think iI screwed my yanmar govenor
   / I think iI screwed my yanmar govenor #1
bootlegger
i have a yanmar 2000, the injector pump was only pumping on one side. I wasnt sure about what i was doing, so i took the 2 nuts, and the two bolts out of the pump and attempted to take out the pump. Well i found out it does not come out that easy, so i put it back together, and started it up, when i did it tried to run away with itself. Could i have done somthing with the govenor???
   / I think iI screwed my yanmar govenor #2
I think your OK.
You probably missed the pin on the slider that fits into a small "Y" shaped link (under the injection pump). I find it easier to remove the inspection cover off the side of the hydraulic pump and, with a flashlight, reset the pump into the Y link. I'm sure you are either on one side or the other and not exactly in the center.
Mark
   / I think iI screwed my yanmar govenor #3
To remove the pump remove the cover on the from the fuel pump box ( 6 screws ) then reach in and remove the snap pin & spacer from the rack, be sure not to drop the spacer. Next remove the bolts & nuts from the pump, pull out a little bit and turn so the notch in the block will let you remove the pump. Why do you think the pump is not working?
Danny
thanks for the info, i got fixed. I had only one side of the pump working. but i have bigger problems now. the pto is staying engaged, the liget makes a noise and the rear end acts like it trying to lock up.
   / I think iI screwed my yanmar govenor #5
More info, (or better explanation) needed. Are you saying nothing happens when you move the pto shift lever? What is a "liget"? Are you saying the diff lock is engaging by itself or it is trying to seize up?
the pto is staying engaged at all times, the lift makes a noise when when raising amd lowering,and the rear end acts like it trying to lock up.
23311 (A51694)
23311 (A51694)
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
