Rotary Cutter I really jacked up my Bush Hog this time.
   / I really jacked up my Bush Hog this time. #21
I would cut a replacement piece out long enough to overlap the damaged area and then weld it in place on on end and then heat the metal with a rosebud. When it is warmed up bend it around the deck making it conform to the curve. Depening on your blade clearance you may want to add a piece of 3/8 rod to the bottom edge inside to add some strength. Weld the rod with proper curve in place before you add the new plate.
Grind and feather the new piece in place after welding.
I would cut out the mangled mess it is simply in your way.
Steve
HYDREMA 912HM ARTICULATED DUMP TRUCK (A52707)
HYDREMA 912HM...
2018 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-250...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
Wright Sentar (A50120)
