Rotary Cutter I really jacked up my Bush Hog this time.
   / I really jacked up my Bush Hog this time. #21
I would cut a replacement piece out long enough to overlap the damaged area and then weld it in place on on end and then heat the metal with a rosebud. When it is warmed up bend it around the deck making it conform to the curve. Depening on your blade clearance you may want to add a piece of 3/8 rod to the bottom edge inside to add some strength. Weld the rod with proper curve in place before you add the new plate.
Grind and feather the new piece in place after welding.
I would cut out the mangled mess it is simply in your way.
Steve
24634 (A55853)
24634 (A55853)
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
Ford 8340 (A53317)
Ford 8340 (A53317)
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2020 John Deere 450M Round Baler (A53485)
2020 John Deere...
