I need your ideas please
/ I need your ideas please #1
StrangeRanger
Northern VT
L3400 HST
Hi,
I'm looking to break up / loosen up the top couple inches of the soil where I want to plant grass.
We built our house going on 4 yrs ago and the soil is very settled and pretty much leveled out. But it's full of rocks. I'm trying to figure out an implement to use or build that will break up the first couple inches of soil so I can go around after w/ my handy bucket and remove most/all of the rocks. I know that part is going to blow, but I've gotten loosen them up first.
Any ideas? I have a box blade, but the teeth are too far apart for what I'm really trying to do. And a tiller would simply get jammed up or broken by some of the rocks.
Thanks,
j
/ I need your ideas please #2
Can't you make a few passes over the same area with the box blade but just stagger over a few inches on a pass?
/ I need your ideas please #3
Personally I think that if you could rent a harley/power rake would be the quickest. But baring that I think your box blade would be fine. Make a few passes to break everything up and then use a landscaping rake to level everything out. That would also you to help bring the rocks to the surface and possibly angling the rake move them into a windrow.
/ I need your ideas please #4
Have you tried a disc? You might be able to borrow/rent one fairly cheap. It would let you control the depth with your 3pt. After a few passes, most of the rocks would be on the surface. Just my 2 cents worth.....
/ I need your ideas please #5
Rent a skid-steer with a Harley Rake or a Rockhound Rake. Cost around here is less then $300 a day.
I prefer the Rockhound because it collect all the rock and debris in the bucket so you can dump it wherever you need to, whereas the Harley windrows all the stuff to the side.
/ I need your ideas please #6
Sounds like an application perfectly suited to a box blade with rippers, precisely what I use mine for, rock harvesting.
Joel
/ I need your ideas please #7
Yard Tool
I would see if you can rent a Yardtool... There is another set of spikes in the back, offset from the front ones. I bought one for $250 used and I like the results. Real heavy and the roller in the back breaks up clumps.
/ I need your ideas please #8
I've had good luck using a landscape rake. It will break up the top few inches of soil and windrow the rocks over to one side for easy pick up. On my rocky ground I can use the loader bucket to scrape up most of them.
/ I need your ideas please #9
Unless the rocks are large, what I have done is to raise the tailgate of my tiller and at an idle till backing up. It dislodges the rock in and upward stroke instead of down. I have loosened up driveways like this. thing is is to not get in a hurry and just go slow, it will toss the rocks out. You will be carrying the tiller as it willl want to dive in. Just take a few inches off the top at a time.
/ I need your ideas please #10
Box blade rip rip rip. north,south, east, west and diagonally, think of the seat time. Pick rocks however you want too.
/ I need your ideas please #11
I would use the boxblade with rippers also, because you have it, and it will work. You won't get it done in one pass, but spending money on another implement or rent isn't worth the little extra time it takes to make a couple of passes. Plus a set of rippers is about the cheapest thing to fix if you break something on a LARGE hidden rock.
David from jax
/ I need your ideas please #12
Ditto what others have said... Don't waste any of your time and effort and go rent a skid steer with a rockhound attachment. You won't be sorry.
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A61572)
2025 Vicsec 30in...
2021 Felling 29FT FT-45-2LP Trailer (A64194)
2021 Felling 29FT...
(1) 30 GALLON (1) 100 GALLON OXY/ACETYLENE TANKS (A64281)
(1) 30 GALLON (1)...
6' 3Pt Disk (A66285)
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
