I Need Suggestions and Advice
/ I Need Suggestions and Advice #1
CFHartman
Keyser WV
John Deer 2210
I have several large pig nut trees (like Hickory nut's). After the squirrel's are done they leave a mess. What would work for raking up the nut hull's. I considered a landscape rake but I don't think it would work. I'm open for suggestions.
/ I Need Suggestions and Advice #2
If the ground under the trees is pretty flat, a boxblade should work well, especially if it has some short grass - the grass will help keep the boxblade from gouging the ground. Obviously you'll need to get the level right on your blades - I have a hydraulic toplink that makes that quick & easy. Your 3pt will let the boxblade float over small humps etc. and in the low spots it will leave some debris but overall it will gather up alot of it.
/ I Need Suggestions and Advice #3
If you have a FEL, I would recommend tilting the bucket so the bottom edge is at about a 30 degree angle to the ground , pointing forward, floating the bucket, and back dragging.
/ I Need Suggestions and Advice #4
There are 3 pt rakes designed for pecan groves. I think the Lienbach Line has a 4 footer.
cvt
/ I Need Suggestions and Advice #5
I would try a pull-behind sweeper. I have an "Agrifab" bought at Lowe's. Sears sells a Craftsman that's similar. Think mine is 42" wide, and it does a pretty good job on such trash.
/ I Need Suggestions and Advice #6
I use a shop-vac for that type of job. It workes great but watch the duty cycle time on the motor so it doesn't over heat.
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Challenger MT700 Series Tractor Parts Manual (A63117)
Challenger MT700...
Fendt FT500 Tractor Light Kit (A63117)
Fendt FT500...
