I Need Suggestions and Advice
/ I Need Suggestions and Advice #1
CFHartman
Keyser WV
John Deer 2210
I have several large pig nut trees (like Hickory nut's). After the squirrel's are done they leave a mess. What would work for raking up the nut hull's. I considered a landscape rake but I don't think it would work. I'm open for suggestions.
/ I Need Suggestions and Advice #2
If the ground under the trees is pretty flat, a boxblade should work well, especially if it has some short grass - the grass will help keep the boxblade from gouging the ground. Obviously you'll need to get the level right on your blades - I have a hydraulic toplink that makes that quick & easy. Your 3pt will let the boxblade float over small humps etc. and in the low spots it will leave some debris but overall it will gather up alot of it.
/ I Need Suggestions and Advice #3
If you have a FEL, I would recommend tilting the bucket so the bottom edge is at about a 30 degree angle to the ground , pointing forward, floating the bucket, and back dragging.
/ I Need Suggestions and Advice #4
There are 3 pt rakes designed for pecan groves. I think the Lienbach Line has a 4 footer.
cvt
/ I Need Suggestions and Advice #5
I would try a pull-behind sweeper. I have an "Agrifab" bought at Lowe's. Sears sells a Craftsman that's similar. Think mine is 42" wide, and it does a pretty good job on such trash.
/ I Need Suggestions and Advice #6
I use a shop-vac for that type of job. It workes great but watch the duty cycle time on the motor so it doesn't over heat.
1995 Ford LT9000 Tri-Axle Dump Truck (A61573)
1995 Ford LT9000...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
