I need my 1952 Ford 8N to start... please help!!
   / I need my 1952 Ford 8N to start... please help!! #11
possible? sure.. especially if headbolts and some juoker didn't retrofit studs.
cramped? yes.. but doable.
i would not be pulling the head till i pulled valve side cover and worked on them thru that. I have gotten N valves freed up using penetral thru the side covers.
exactly what i mentioned.
pull valve side covers... i bet for find the intakes for 1 & 2 stuck open.
I pulled the covers for 1 and 2. What should I be looking for? All looked good. I turned over the engine and all 4 valves moved. Basically what looked like up and a 1/4 turn. Will upload video when I get back to broadband.
Is that what I'd be looking for?
   / I need my 1952 Ford 8N to start... please help!! #13
Unfortunately if you verified they are all moving just as much as one another, then start taking that hood off.
   / I need my 1952 Ford 8N to start... please help!! #14
yup.. if you have cyls with -0- compression and the valves are all moving the same.. then that's bad.
like holed pistonshattered cyl liner..
deffinately start taking hood off...
   / I need my 1952 Ford 8N to start... please help!! #15
Or look on craigslist for one that is running. :thumbsup:
Buying one that is running might be cheaper in the long run.
   / I need my 1952 Ford 8N to start... please help!! #16
Depends on what is wrong really
Here are the vales from the cover plate angle...
   / I need my 1952 Ford 8N to start... please help!! #18
I have a 8n, and your motor should be turning over faster than that. I would bet it is either a broken ring or a whole in the piston.
Sent from my DROID RAZR HD using TractorByNet
   / I need my 1952 Ford 8N to start... please help!! #19
even a broken ring will make some compression. a snatched out liner or holed piston could put out near zero though
   / I need my 1952 Ford 8N to start... please help!! #20
Broken crank will allow 3and4 to turn over 1 and 2 won't. Does the fan turn while you try to start it?
Caterpillar D6K Crawler Tractor Dozer (A50322)
Caterpillar D6K...
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
10' Feed Bunk (A50515)
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
(4) 16' Tarter Corral Panels (A50515)
(4) 16' Tarter...
2019 Doosan LCV6 Towable Light Tower (A51691)
2019 Doosan LCV6...
