I need gravel bad!
   / I need gravel bad! #31
Sorry to intrude on this topic but I have a question. My driveway which is used by 12 houses has some spots were rocks are starting to come up thru the road bed. the rocks are only up a little bit maybe the 2-3 inches high and 6 around but the rest of the rock underground is huge. I know I probably cant move the rocks but is there a way I can cover them with other gravel to even it out some?
Dave
   / I need gravel bad! #32
You can always add more gravel. If I understand your situation, I would use a sand gravel mix like #304 or #411. This will be fine enough to fill in the voids and pack nicely.
Keep in mind If you have frost there, the big rocks are going to continue to heave up.
   / I need gravel bad! #33
We only have surface frost nothing that penetrates the ground much. The rocks are spaced about 6 -`2 inches apart randomly. The rocks here seems to "grow" they come up over time.
Dave
   / I need gravel bad! #34
Frost and erosion are the only 2 things I can think of, that would cause rocks to "grow." a small backhoe would be handy to yank some out once in a while. using a grader box can be tricky with buried rocks, (I would go slow). But, it would be the best way to finish the drive, after "tailgating" down the stone. Unless all your neighbors bring their rakes, and you have a "Raking Party." Spread it out, wet it down, and compact it, (drive over it a million times).
   / I need gravel bad! #35
Pretty clear what the gold standard solution is, strip the topsoil down to the old gravel base, ditch arq, lay geotextile fabric and then considerable gravel. Result should, ideally, stand proud of surrounding dirt, w. edging arq so as not to repeat the current situation. Here are some interesting reading links; then, take whatever shortcuts make sense to you.
http://www.cyber-north.com/geotextiles.html
www.maine.gov/dep/blwq/docwatershed/camproad.pdf
www.agf.gov.bc.ca/resmgmt/publist/600Series/644000-2.pdf
http://www.umext.maine.edu/waterquality/lakes/LakeASyst/camproads.htm
http://www.epa.gov/nps/gravelroads/
   / I need gravel bad! #36
I have Oscar88's problem: a 1/3 mi. of deteriorating road bulldozed through alluvium in the foothills of the desert SW. Parts are rather steep. The alluvium is a mixture of rock from 1" to 12" with a matrix of sand and powdery caliche. There are a few rock shelves.
The road is eroded by rare torrential rains, wind when it is dry (most of the time) and spinning wheels, especially delivery trucks.
Over the years the road has been groomed at intervals with a maintainer (grader), which keeps cutting spoil out of the high side of the road, so making it wider and wider. After grading I would usually add 1 inch crushed rock, and pray for rain. The best time to do this is a few days before July 4th, when the Mescalero Indians do their rain dances.
The road has got so bad now, and I don't want it to get any wider, so a new strategy is in play. I am pulling spoil off the lower bank of the road with my TBL, and spreading it best I can with the FEL, filling in the wheel ruts that have developed, and building up the surface to cover the exposedrocks: this is not easy because of the larger rocks. I have to keep getting off and tossing off the larger rocks. (Lacking a source for the spoil, it would have to be trucked in.)
I'm re-shaping the road so that it drains towards the downhill side of the slope it is cut in. I have put extra material over the exposed rock shelves. (I am trying an experiment - I put come mortar mix on the rock and covered it with clean gravel, hoping it will hold the fill better.
I am puttin in a couple of broad, diagonal berms on the steeper part to supplement the side slope and help the rain divert off the road (broad berms so the small cars like my Prius don't get high-centered).
The parts I have finished are quite uneven and bumpy, because of the rocks in the mix. I'm not about to take off the backhoe to put on a blade: besides, the TBL wheelbase is too short for blade work on an uneven surface. I have wet down the surface with a hose to the extent my well and availability of borrowed hose will permit to help bind the materials.
I will complete the surface by bringing in base course and spreading it to about 3": it will cover the bumps and create a maintainable surface (this is the expensive part). If the base course is fairly dry, the driver can spread it evenly from the tailgate. Base course here is what precedes asphalt for road building, and is composed of 3/4-minus crushed rock mixed with sandy clay.
If we ever get rain (it hasn't rained for 3 months during what passes for winter here!), I'll pack the base course best I can with a truck, and if necessary add a layer of 3/4- crushed rock, or grinder fines. I hope that occasional blading and addition of a little topping will keep the road up in the future. (I have a neighbor who has an excellent blade on his ancient tractor who will help me out occasionally).
I'm close to finishing the first half of the job, having worked on it intermittently for several weeks and will be bringing the base course in soon, to prevent the material I have disturbed from blowing away.
I don't think that a layer of gravel is sufficient to hold up for more than a year when the surface is destroyed and the big rocks starp appearing and popping out. You need to re-create a sufficient depth of material that the rocks are well-covered and so that you have a maintainable (bladeable) surface. In my case it is a major project. A contractor could do it in a few days with heavy equipment, but at what cost?
I hope this gives you some ideas, Oscar.
Charlie
an update.
the serious mud seemed to be a unique situation that only occurs when its thawing. The underling ground is still frozen and the upper few inches thaws, but with no were for the water to go, the freeze/thaw really breaks up the dirt into a squishy unbelievably soft muddy mess.
I managed to spred most of the large rock i had in the back durring the soft period. I would get out early in the morning when things were still froze. within a day or so of putting it down most (the stuff in the squishiest areas) sank in flush and did seem to add significant firmness when driving on it. (we no longer got stuck)
about a week pasted, thaw finished, and things "dried up" enough that we were able to work in the garden and i could drive the tractor through the yard without sinking to the hubs.
Then the rain came. I thought oh god no, not more slushy mud. but like i remember last year (this time of year) it wasnt bad. ya the bare areas got muddy but you didnt sink in to them 3" with the cars. IE the water ran off the top.
To finish off my story i had 15 ton of grade 8 (1" minus) delivered this morning. $230 with delivery (i dont know what was gravel price and what was delivery price) but it was about what i expected for a "full" load)
Ill post some pics of what im starting with and the finished product. (sorry thing is i expect to put a 20x30' concreet pad down right in the middle of the worst of it within a few months.... oh well)
2001 Acura MDX SUV (A55758)
2001 Acura MDX SUV...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
