Buying Advice I need a better wheel barrow!
   / I need a better wheel barrow! #21
I googled the implements mentioned. They make lots of stuff especially stuff for little tractors. I though I had seen it all when I saw the land plane and the spring loaded job. It looks like there is more than one PTO output shaft?
Very generally, with exceptions: Subcompact tractors (1,700 pounds) come standard with a center and rear PTO. Center PTO is to power mid-mount-mowers.
Some compact tractors (2,700 pounds) have center PTOs, some do not. Center PTOs are omitted to reduce prices. Downside to center PTOs is that they can clog/plug/bind with dirt and dust when infrequently used.
Heavier tractors (3,500 pounds +) have optional center PTOs, primarily to operate front mounted snow removal equipment. Snow removal is the primary task for many tractors.
Rear PTO is integral to every Three Point Hitch.
IMPLEMENTS: http://www.lsuagcenter.com/~/media/...aa214276e14dacb/pub2917tractorimplements1.pdf
   / I need a better wheel barrow! #22
Jeff,
I think you got your road cut a bit low in one spot in photo #1. Lol. I thought I would cast a concrete weight or use the iron weights from the old case.
Girl,
I have some well meaning friends who encourage me to just hydroax all the Cedar and remove all my 100 year old stunted oaks because they're "not worth saving". They like the huge one time rental /hire it done approach.
I don't like that idea much. Pretty much all my trees are of the "not worth saving" variety. If i hack and slash, I am left with a rock pile in an endless summer of 100°F plus days. I want to take my time, consider my views, and weigh the value of each tree. In short, I need a hobby.
My old 16 hp Mackissic chipper would chip 4" dried oak slowly. I rented a 16 hp stump grinder that was a beast. I figure somewhere in the 25 to 40 hp PTO will do what I want. I liked the look of this Chinese Canadian stuff:
Wood Chippers – Woodland Mills Canada
We just sold off the livestock and moved from ag exempt to a wildlife exemption. Part of that involves clearing, adding brush piles, and adding water sources.
Heavier tractors (3,500 pounds +) have optional center PTOs, primarily to operate front mounted snow removal equipment. Snow removal is a primary task for many tractors.
Actually, I meant the rear PTO. I see a 6 spline, a 20, and Kioti has a square? (Poor photos. Hard to tell.) I don't have a lot of interest in snow removal. I probably would spend the optional center PTO money on front or rear extra hydraulic circuits.
A boom pole, log arch, or gin poles are definitely an option.
   / I need a better wheel barrow! #25
Thought you were talking about existing stumps. I would NEVER suggest cutting down trees without a very, very good reason. Esp in a hot climate, trees are golden. Don't let the "clear everything" people talk you into it. A 100-year-old tree "not worth saving"??!!
How I ended up with stumps, trees to chip: I have 13 acres of deep woods and chose to clear one very small area, including some larger trees, to create a natural spring-fed pond (the wildlife loves it) and also did some general thinning of doomed poplar saplings to give the chestnuts, oaks, wild cherries, maples, hickories, and pines a better chance to grow.
That's wonderful you'll be enhancing your land by creating wildlife habitat. A fun, rewarding, life-long hobby!
I have also created natural wildflower and native grass meadows which are beautiful and only require mowing once a year. I also leave standing dead trees as long as they're not right near the house. Attracts all sorts of wildlife. Also left large areas of brushpiles (again, not in view of the house). I purposely have left around 5 acres of dense woods completely untouched; I don't even walk there. It's a dark, steep, jungly place and who knows what lives there? I like that. I have heard the calls of some rare birds that only live in undisturbed woods. :)
   / I need a better wheel barrow! #26
That's wonderful you'll be enhancing your land by creating wildlife habitat. A fun, rewarding, life-long hobby! I purposely have left around 5 acres of dense woods completely untouched; I don't even walk there. It's a dark, steep, jungly place and who knows what lives there? I like that. I have heard the calls of some rare birds that only live in undisturbed woods. :)
There may be a squatter living in there. :0
Well, i am doing it because it saves roughly $15,000 in annual taxes. The tax man is requiring more cattle than the land will support. It is nice to see the gray fox in the very early morning. We have horny toads. There is a pair of mountain lions a little les than two miles away. I think the roadrunners are hilarious. I could do without the coons and possums.
All we really had to do was remove the cows and add a small amount of water. The wildlife just exploded. It was nearly instant.
I am encouraging the native short grass prairie. I feel a little silly carrying my tablet around looking for shade to compare photos of grass against what is growing. The burn bans forced on us because of the transplanted city people are a definite drag. We are discussing removing the cedar or "mountain juniper". My oaks are stunted because they have rocky feet. The rings are so tight you can barely count them. People dont understand how a hundred year old tree can just be 20 ft tall and have a trunk six inches thick. I am just glad the oak wilt hasnt gotten them.
You're right. It is an entertaining hobby.
   / I need a better wheel barrow! #29
Compact tractor PTOs are standardized with six spines. No square ended shafts. One rear PTO per tractor.
Anything additional is powered hydraulically, rather than mechanically. Mechanical power transfer is much more efficient than hydraulic power transfer. PTO power transfer is for continuous operation. Hydraulic power transfer is for intermittent operation, opening and closing valves.
Hydraulic pumps on tractors are much smaller than hydraulic pumps on skid steers.
Big ag tractors (9,000 pounds, bare tractor) with 1,000 rpm PTOs, may have 20 splines on larger diameter shafts. I am not certain of the spline count.
Three Three Point Hitch and standard PTO was introduced to the USA from England in 1939 and has been standard since, although larger sizes have been introduced as tractor weight and power has increased. Tractors of the 1940s were designed to replace two horse plow teams with a better tool.
(Has some odd grey market stuff been imported in minuscule quantities? Yes.)
When ordering PTO powered implements, if you have a Category 1 hitch and order a new Category 1 implement, they mate.
( Cat 1 and Cat 2 are compact tractor sizes. Big ag tractors use Cat 3 through Cat 5)
Tractors in common weight categories are mostly generic. The Three Point Hitch dimensions are to industry standard, although hitch lift capacity and lift height varies. When you get into details compact tractors vary in horsepower, standard versus deLuxe kit and paint color, which we obsess about in this forum.
   / I need a better wheel barrow! #30
go cut, you will be glad you did, kind of hard to recommend anything outside of that since you have dealer concerns -
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
TANK MANIFOLD (A58214)
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
