I made it myself
/ I made it myself
Scrounger and all; I didn't expect so many kind words. Thanks all.
Matthew, The main parts are all 1/4X3" channel. The tabs are 1/4"X3X5, the square tubing I picked up at TSC for about $13 and that was the only cost. The gussets are 1/4" and about 5X5". The horizontal crossmember is 24", and the upright is 16". I used 7018 rod at the plant for horizontal and verticle pieces, the brought it home and 6011 on the rest. Hope that helps.
I LOVE paint!! /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
I plan to chain down the 3pt around my drawbar when I move anything that might get tail heavy.
Next trinket will most likely be a boompole made of 1/4" square tubing when I get the chance. /forums/images/graemlins/grin.gif
/ I made it myself #42
Regarding the appearance of welds in general, say what I say and they look great......"That's not going anywhere" /forums/images/graemlins/grin.gif
/ I made it myself #43
One of the handiest things you could ever build! When you get a chance add a ballast box to it with provisions to carry your chains etc. Don't worry about pulling heavy loads- how much drag does a moldboard plow or backblade put on your tph? Just don't try to jerk too hard on a chain without a nylon "shock-absorber" strap. As far as down pressure, you will know by the tongue weight if it will be a problem. I have a 1 7/8 ball on mine and pull 2" and 2 5/16" trailers around constantly, most times I don't even latch the 1 7/8 trailers, just back up under them, raise the 3pth and drive off. Great job-Pat
LOT LOCATIONS (A59908)
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2019 BOBCAT SKIDSTEER T740 (A60736)
2019 BOBCAT...
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
Electric Concrete Mixer (A61166)
Electric Concrete...
