I knew it!
/ I knew it! #1
daTeacha
Funk, Ohio
Somehow I knew from the title that Doc Bob's thread would be closed. I was surprized you guys kept it acceptable as long as you did. :)
/ I knew it! #5
My apologies for any offense I may have caused. I have reposted using the words "loose devices". I still need help on how to correctly adjust the "loose devices".
Bob
/ I knew it! #6
Bob
Doc Bob,
Geeze. We accept your apolgies for such a grave offense. But, now how do we answer your question without using offensive terminology?
Oh well, here goes --
I see two simple fixes.
One is to use NYLON INSERT LOCKNUTs. Any reasonable hardware store will have them. The nut is metal, the threads are nylon. They take a little effort to get on a rod as long as your throttle linkage, but they won't move once you get them installed. You could replace both nuts, or you could just tighten one of these locknuts against the nut on the open end of the rod.
Another solution would be to use Loctite thread locking adhesive. Again, most any reasonable hardware store, or automotive parts store, will have
Loctite Red 271. There are several Loctite thread locking forumulas, but this is the most popular and the easiest to find. Before you tighten the nuts into position, apply a few drops of Loctite onto the rod threads. Then tighten the nuts into place. They should stay.
Good luck,
Knute
/ I knew it! #7
I'm surprised there were not pal nuts installed.
Soundguy
/ I knew it! #8
Soundguy
What are PAL nuts? What does PAL stand for?
Bob
/ I knew it! #9
knute_m said:
Doc Bob,
Knute
I will get some Red 271.
Thanks.
Bob
/ I knew it! #10
Bob
A retaining nut. I guess a jamb nut might be more applicable in this setup.
Soundguy
/ I knew it! #11
Soundguy
I always thought a palnut was one of those little tophats...
/ I knew it! #12
two things..
1) will someone PM me about what I missed? I need a good laugh today.
2) I would use the Blue Loctite. NOt KNowing if you want this to be permanent or not.... Red is considered the permanent loctite. VERY hard to get apart. We use Blue Loctite in our Backhoe mount kits.
/ I knew it! #13
Yes.. I think those qualify, as well as many other kinds of 'push' nuts. I've seen them used as retainers and whatnot.. but after thinking about his application.. a jambnut would be superior.. etc.
soundguy
/ I knew it!
Personally, I would just use two of the internally threaded friction based fastening devices on each side, tightening the outermost against the innermost to prevent either from turning. You could also put a simple split or star type lock washer between the members of each pair. The internally threaded friction based fastening devices are tightened with a device known as a wrench.
/ I knew it! #15
Why buy a locknut to add to the regular nut.. when a jambnut will be cheaper and accomplish the same thing? ( 2 nuts tightened slightly against each other... ) Heck.. add a drop of the green loctite afterwards... kill the vibration problems..
Soundguy
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
John Deere Zero Turn Lawnmower (A65579)
John Deere Zero...
