SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,520
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I wouldn't consider grade 8 bolts brittle. The grade rating is a measure of material strength not hardness. I machine and drill them all the time. DP hit on a point though. If the bolts are snaping in shear or tension, a larger bolt or more bolts should help. It's the same reasoning used to hold a head on an engine. You won't find any 1/4" bolts on a diesel engine.
A misread id say. The brittle - ductile thing is a matter of degree. Regardless, mechanical strength generally goes up with hardness - with accompanied loss in ductility.You said grade 8 bolts are to brittle, they aren't. They are ductile just like lower grade bolts. They just don't show deflection or deformation until much higher stress levels. And reference books are there for just that, reference and specifications.
larry
