I just bought an Echo 2511t clone for $99. What was I thinking?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #21
I've got a rear handle, but you folks make me wonder if maybe I went wrong. 🤣
   / I just bought an Echo 2511t clone for $99. What was I thinking? #22
Joncutter... What is it for, cutting up toilets? I'll keep my top handle Echo thank you. Far as saws go, any saw, Chinese or not will cut good with a properly sharpened chain....
I will say the Echo really requires breaking in a bit, couple tankfulls of syn gas (Echo Red Armor) in my case, bring the best out if the saw and it's my favorite for limbing and smaller dialeter cuts and it don't need no stinking, noisy Egan muffler either. Always fires up second pull as well.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #23
Dont go cheap on echo 271T like you did either. Way heavier and less power. :ROFLMAO:
Take a clone 2511 over that 271T clamshell homeowner saw any day.
271 dont have the power to even cut up a toilet. :ROFLMAO: šŸ˜‚:ROFLMAO:
You notice they didnt pick a 271T to clone. Good reason for that.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #24
Echo 2511 oem pro grade saw in rear handle weighs less then that homeowner clamshell cheap 271T saw.
2511 TH about 7 ounces less then rear handle 2511 too.
I have passed on used 271T for 75-100 here as they are crap turds IMHO
   / I just bought an Echo 2511t clone for $99. What was I thinking? #25
2511 OEM and clones built right. Bolt on cylinders like they should be for a pro grade saws.
Not some clamshell thing like echo 271, cheap poulans and stihls.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #26
echo 271T = no thank you. My 94 poulan top handle built better then that thing.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #27
2511's oem and clones. Geter done. šŸ»
   / I just bought an Echo 2511t clone for $99. What was I thinking? #29
Look what you made me do....
put in an order for the $100 special.
That less money than a pair of batteries for the Makita electric.
It's going to have a permanent home in the tractor scaboard....
thanks you guys! ;-)
   / I just bought an Echo 2511t clone for $99. What was I thinking? #30
Your top handle Echo is nowhere near as good of a saw as the 2511 is. The 271 is not a fan favorite by any stretch of the imagination.
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
24638 (A55853)
24638 (A55853)
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
