I join you guys today with my new CK27 HST
   / I join you guys today with my new CK27 HST #21
Mousefield, with my CK35 HST, I've found that the rpm range of 1800 to 2000 works smoothly under a FEL load. Higher only if I'm really bulling something. Higher than 2000 for normal loader work seems excessive, just intuitively based on the engine sound and performance.
HST consumes only a small amount of power. Not sure how much, but not much.
   / I join you guys today with my new CK27 HST #22
Mousefield,
My dealer, when I asked him yesterday, said just enough RPM's to climb my driveway hill is all I need.
If the engine lugs, give it some juice...
He did say a DK40 would struggle up my driveway quite a bit more than mine.
David
   / I join you guys today with my new CK27 HST #23
Mousefield, with my CK35 HST, I've found that the rpm range of 1800 to 2000 works smoothly under a FEL load. Higher only if I'm really bulling something. Higher than 2000 for normal loader work seems excessive, just intuitively based on the engine sound and performance.HST consumes only a small amount of power. Not sure how much, but not much.
To me 1,800-2,000 RPM's just feels a bit slow, to me around 2,200 or a bit more feels "right" :cloud9: to me.
   / I join you guys today with my new CK27 HST #24
I also go by sound and lugging. Always have. Ive never been set that it has to be running at 2,000 or 2,200 or 1,800. It depends on the terrain, the load and what your doing with it.
Hy HST works great if driving empty with the rpm at 1800. No issues. Under load i want more.
I also think you need to add the rimguard to the rear tires. Makes a world of difference in lifting capacity and quality of the ride. There is NO way short of a huge ballast box that i could haul full bucket loads of gravel with my DK45 if the tires were empty.
When backing up, you may also have to engage the differential lock lever if there is slippage. What you don't really want is for the 4x4 to be engaged and the rear tires off of the ground, as you can over stress the front wheel drive system.
   / I join you guys today with my new CK27 HST #25
I was told by different dealers and Kioti mechanics that you should stick to 2000 rpms minimum when operating the HST as any less does not create enough hydraulic pressure and could cause harm to the HST unit over time. I run from 2000-2500 depending on work with the loader, 1800 rpms for backhoe work and 2800 rpms for snow blowing so the rear PTO is at full 540 rpms.
As far as your loader work, you certainly need some weight on the rear and use four wheel drive to help with traction. You shouldn't need full throttle and low gear for any hill. I could climb vertical walls in low gear at 2500 rpms so either your just losing traction or not getting full power from the HST. Also, after the 50 hour service, you'll notice the engine getting more powerful as it breaks in.
   / I join you guys today with my new CK27 HST #26
I have a ck25 gear. I've moved over 1000 tons with it. its a beast. But, I've got to believe it would have been unsafe to move what I moved without loaded tires. Loaded tires is a definite. Rear implements/weights are good and all, but they can also get in the way, and sometimes you need both.
I think your price is fine, especially in canada.
Also get a toothbar. Really makes a difference digging into a pile.
From what I understand, mfrs recommend running HST's at or near PTO rpms so that sufficient pressue is developed for the hydrostatic tranny. My john deere explicitly says to run at full throttle when traveling. Plus, your loader will perform so much faster and stronger above 2000 rpms.
   / I join you guys today with my new CK27 HST #27
If this were true for my Mahindra 3215HST, I would sell it. My manual says to operate at a minimum of 1500rpm and depending on what I am doing I usually run between 1800 and 2200 rpms. I'm not sure if I have ever even had the tractor to full throttle. It may well be just what I use the tractor for, but I cannot imagine having to run it as high of rpm as so many on the board say that they do. :eek:
As far as loading the tires, you have seen first hand how it works without. :( Now go fill the tires and you will think that you just bought some monster. Truly a day and night difference with how the tractor will perform and with filled tire you WILL be able to work the tractor to it's true capabilities. :thumbsup:
Just my :2cents:
   / I join you guys today with my new CK27 HST #28
Just my :2cents:
i nevr run it that high, but maybe i should pull out my manual and see what it says.
UPDATE: Manual says....nothing. no info at all. Guess ill call my dealer and check, as i dont want to cause an issue.
   / I join you guys today with my new CK27 HST #29
What gets me is that I am fairly certain that the recommended RPM for Kioti is not the same as what it is for the Bobcat. :confused2: Just like on the Bobcat forum there are guys saying that the warranty is void if you fill your tires, but I don't ever remember seeing that about Kioti. :confused3:
   / I join you guys today with my new CK27 HST #30
WHAT... filled tires void warranty. thats insane.
I contacted Kioti direct and talked to rep. They recommend filling tires, and told me that tire chains on front are also allowed. I heard some brands void warranty if you run front chains.
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
Dewalt DW723 Rail (A57454)
Dewalt DW723 Rail...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
