I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start.
   / I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start. #1
fastfreddies
Kubouta
The mule runs good but it can be hard to start cold or warm. I go through the start process, turn the key on wait for the glow plug light to go out, and crank it sometimes it starts, other times it just cranks allmost starting. When it dose start there is alot of smoke. The battery is new, the fuel is fresh, air filter is clean, if I put a jump box on it, it starts up after cranking. Any help will be appreciated.
   / I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start. #2
What happens if you wait for the glow plug light to go out - turn the key off - wait a beat, and then turn the key on again to activate the glow plug a second time, then crank when the light goes off?
I have tried that with no luck. I was thinking maybe it needed more heat.
   / I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start. #4
Maybe new glow plugs?
   / I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start. #5
It’s been my experience that when testing g plugs with a battery charger, they need to be cherry red within 10 seconds..
   / I have a 2021 Kawasaki mule PRO DXT Diesel 4x4 I bought used it is hard to start. #6
If you have a load tester I’d test the battery even though it’s new, probably not the problem. How is the fuel filters? A good running diesel shouldn’t need glow plugs to start when it’s warm out.
2000 C&B Custom Modular 12ft.x40ft. Mobile Office (A49339)
2000 C&B Custom...
2017 Kawasaki Mule 4010 4x4 Utility Cart (A46684)
2017 Kawasaki Mule...
2012 Ford F-350 Omaha Service Truck (A48081)
2012 Ford F-350...
2017 ISUZU NPR/NPR-HD (A46683)
2017 ISUZU...
2014 Fiat 500L Hatchback (A46684)
2014 Fiat 500L...
2012 GALYEAN 130BBL VACUUM TRAILER (A48992)
2012 GALYEAN...
