I HAVE A 2003 BRANSON 4720 .
/ I HAVE A 2003 BRANSON 4720 . #1
BUDGET 103
2003 BRANSON 4720
I HAVE A 2003 BRANSON 4720 . I REMOVED THE HYDRAULIC HOSES TO INSTALL A 3RD FUCTION FOR GRAPPLE. SINCE THEN THE REAR HYDRAULICS HAVE NOT WORKED . SO I PUT EVERY THING BACK STOCK AND IT STILL DONT WORK. MORAL OF THE STORY IS I DIDN'T TAKE ANY PICTURES. I NEED SOMEONE TO TELL ME HOW TO ROUTE ALL THE HOSES FROM THE PUMP TO THE FRONT END LOADER VALVE , TO THE REAR OF THE TRACTOR.
/ I HAVE A 2003 BRANSON 4720 . #2
Step one turn off the damned cap lock.
Step two, follow the fluid flow from the pump into the pressure port of the loader valve, then you should have 4 lines going to the loader cylinders, from the valve body there should be a low pressure return to tank line, and 3rd high pressure line from the power beyond port of the valve to the tractors connection to the 3 point.
1999 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61568)
1999 Fontaine...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A61165)
2017 Mitsubishi...
2022 North Star Pressure Washer (A60352)
2022 North Star...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
