I guess the frost is out (stuck)!
   / I guess the frost is out (stuck)! #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Well, I finally got stuck. I knew my yard is soft, I had pulled an old toolbar cultivator out of my uncles bush and wanted to see if it would dig in so I picked what I thought was one of the higher, more dry sections to take a test run. Shortly after I got in I realized I was in a little softer than I thought. I lifted the cultivator which wasn't doing much anyway and drove straight thru. On the way back I sunk even more and the hitch and culti started dragging. The photos show the front after I lifted it out with the bucket. After I disconnected the culti I was able to curl myself thru. The culti is still there. What a mess:eek: Oh well I was going to tear it all up anyway:D
   / I guess the frost is out (stuck)! #2
Another sign of spring...just one more pass.;)
   / I guess the frost is out (stuck)! #3
those r-4's do clog up fast dont they.
   / I guess the frost is out (stuck)! #5
they look too wide to be ag's i thought.
You're both correct. They are R1's but with the mud on them they are about 12" wider. I just noticed on my way in the yard, the mud is still on the tires and the tractor is so wide it looks ready for a tractor pull;)
Brent
   / I guess the frost is out (stuck)! #7
Atleast you were in the cab.:D When my dads 3720 gets stuck, it comes back with mud all over the operator station. Then I scrape mud off whenever I get on. Im sure you know what that means, BATH TIME! :)
   / I guess the frost is out (stuck)! #8
Wow, that looks worse than my tractor last year when I decided to go out and with the 3pt. discs last spring.
I would stay out of that lawn till next winter:D
This is one of the reasons I'm getting ready to tear up the whole yard, I really need to deal with the slope and water sitting. I'm hoping it will create a better base to get some real grass in the yard this year.
Brent
   / I guess the frost is out (stuck)! #10
wow thats alot of mud stuck to the outside of the tires. i have a soft spot i'm going to be working on this summer but it's nothing like that.
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
