I guess the frost is out (stuck)!
   / I guess the frost is out (stuck)! #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Well, I finally got stuck. I knew my yard is soft, I had pulled an old toolbar cultivator out of my uncles bush and wanted to see if it would dig in so I picked what I thought was one of the higher, more dry sections to take a test run. Shortly after I got in I realized I was in a little softer than I thought. I lifted the cultivator which wasn't doing much anyway and drove straight thru. On the way back I sunk even more and the hitch and culti started dragging. The photos show the front after I lifted it out with the bucket. After I disconnected the culti I was able to curl myself thru. The culti is still there. What a mess:eek: Oh well I was going to tear it all up anyway:D
   / I guess the frost is out (stuck)! #2
Another sign of spring...just one more pass.;)
   / I guess the frost is out (stuck)! #3
those r-4's do clog up fast dont they.
   / I guess the frost is out (stuck)! #5
they look too wide to be ag's i thought.
You're both correct. They are R1's but with the mud on them they are about 12" wider. I just noticed on my way in the yard, the mud is still on the tires and the tractor is so wide it looks ready for a tractor pull;)
Brent
   / I guess the frost is out (stuck)! #7
Atleast you were in the cab.:D When my dads 3720 gets stuck, it comes back with mud all over the operator station. Then I scrape mud off whenever I get on. Im sure you know what that means, BATH TIME! :)
   / I guess the frost is out (stuck)! #8
Wow, that looks worse than my tractor last year when I decided to go out and with the 3pt. discs last spring.
I would stay out of that lawn till next winter:D
This is one of the reasons I'm getting ready to tear up the whole yard, I really need to deal with the slope and water sitting. I'm hoping it will create a better base to get some real grass in the yard this year.
Brent
   / I guess the frost is out (stuck)! #10
wow thats alot of mud stuck to the outside of the tires. i have a soft spot i'm going to be working on this summer but it's nothing like that.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
