Generator I found an unused PTO generator
   / I found an unused PTO generator #11
arrow said:
The lady said her next door neighbor stated to her that these new cost over $1000 so she wants $500 and she would not allow me to take it back to my house to put on my tractor as she no longer has any tractors. I asked if it did not work would she give me my money back. She said sure so I got this thing home and attached and it turns it but it will not even power my drill up. How long can a PTO gen t sit w/out being used. I though about forever but am totally ignorant about gens. I wanted a PTO gen so as to not have to worry about starting it once in awhile like a gas gen.
Fire it up, plug a cheap 1/4" single speed drill into it and turn the drill chuck by hand. The drill will probably 'flash' the generator and you may be in business.
   / I found an unused PTO generator #12
But you do need to start it. One of my generators manual says run it once every 3 weeks to drive moisture out. You will probably need to do the same for yours.
   / I found an unused PTO generator #13
Make sure you hold the switch to the drill on when you do this.
I bet you could also use a cordless drill chucked tot he cheap drill, hold the trigger and let it power up that way.
soundguy
   / I found an unused PTO generator #14
soundguy
A cordless drill coupled to a electric drill works fine.....use a small 1/8 inch piece of wooden dowel to connect the two drills together at the chuck. A small stick will also work. You want the dowel or stick to break and un-couple the two drills when the generator starts charging and the electric drill starts to spin.
Thanks for all the tips. I tried the drill trick and still no charge. I brought it back and the kicker of it was she was reluctant to give me my money back. How does she know I didn't break it she said. Thankfully I had written that part of the agreement into the bill of sale and threatened small claims court. She conceded and I gave her $50 bucks for her anguish. Some people got more trouble in their lives than you can shake a stick at and thsi lady has some. I'm just going to buy new. For $300 more it isn't worth it to me to go thru these kinds of hassles. Thanks again.
Lou
   / I found an unused PTO generator #16
Too bad it didn't work... would have been a nice find.
I usually try to power my pto gen up once every couple months, though i have gone 6mos with no problems..
soundguy
It did teach me I don't have the patience to go get the tractor,bring it to the barn, hook up the pto for the multitude of little power glitches and maintenance running. I'm better off with a good portable with hook ups in the barn so I don't have to move it and just yank on a cord. Especially if you have to run a pto gen like you do a regular gas gen periodically. I thought the pto gen would be a buy it , don't have to look at it until you need it thing.
   / I found an unused PTO generator #18
Very smart move, you really don't need the hassel
   / I found an unused PTO generator #19
You probably need the tractor to do cleanup after any event where you need the generator. It's good to be able to operate both simultaneously.
   / I found an unused PTO generator #20
That's what 2 tractors are for! ;)
soundguy
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
